Question about Kenmore 64802 Top Freezer Refrigerator
The freezer is set to the coldest setting. I am assuming that it does not maintain this temperature consistently because my ice cream looks like it melted and the re-froze. What is wrong?
  • 4,066 Answers
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Posted on Dec 29, 2010
Freezer Constantly Runs.
Do you know what design temperature is for that freezer? Some are meant for 0 degrees others for -10 or 15. I would say you are trying to maintain -10 for a food freezer and trying to keep ice cream frozen. Ice cream freezers need to be colder than food freezers. I know it sounds dumb but look it up. Check the door gaskets to see that there is no leakage and the surrounding area should be no higher than 75 degrees, (otherwise it\'ll run all the time). Hope this helps and good luck.
Apr 20, 2014 | True 72 cu. ft. Commercial Freezer TS-72FG...
Jenairrefridgerator model jcd2292ktb, what is the temperature for freezer and refridgerator
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Refrigerators
What is freezer and refrigerator temperature suppose to be set on
Jun 20, 2012 | Jenn-Air JSD2789GES Side by Side...
Ice cream does not seem to freeze it is always very soft. Everything else freezes O.K.
hi icecream generaly depends on the mixture & consistency need more clarity....
All fresh ice cream is somewhat soft, but should not be liquid. It will never be hard like it is in store. Let it churn until it is the consistency of soft ice cream, and then let it harden a bit in the freezer to get to the consistency you want. It's possible you actually let it churn too long and it started melting again.
Another method I used is to just put the ingrediants in the bowl, put in the freezer, and then take it out of the freezer and churn it myself, moving a butter knife around the edges to get all the frozen parts out, then a fork to mash it up. The ice cream takes less time to freeze and is generally harder
Aug 08, 2011 | Refrigerators
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Hello. The company I work for recently purcahsed an F13BR36-C ice cream cabinet with remote condensor unit. I've installed the condensor unit; however, there is no temperature control for the cabinet and...
You need to install a thermostat to cut off control power to condenser contactor at a set temperature that you will have to set, let's say; 5 degrees for example. You should be able to purchase a thermostat at any A/C & refrigeration store. If you are familiar with control, this should an easy job.
Good Luck!
Dec 17, 2010 | Delfield Refrigerators
What setting between 1-9 should I set Freezer to prevent freezer burn
Good day,
Freezer burn is due to too cold a temperature in the freezer compartment. Nominal for that machine is 4 to 5.
However only time will tell you what is acceptable, since freezer burn can occur even at a warmer setting, if the product is stored a long time.
1 is warmest and 9 is coldest. I would lean to a slightly warmer setting to start off but that will create a trade off, since it would reduce the speed of ice production, and with especially high quality ice cream, possibly ice cream being too soft.
Patience is your friend here. But what you want is there.
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Simple Vanilla Ice Cream from recipe booklet is still staying liquidy. Have done everything as instructed. Ingredients are well chilled and ice cream bucket has been in the freezer for two days. Have had...
Your freezer is not cold enough. I had a heck of a time with this machine the first few attempts, when I was in storing it in my main freezer (less cold than the one in my garage). Then i froze the bowl in my garage freezer - it is set to below 32 degrees Farenheit and is designed for long-term storage (gives anything I put in it major freezer burn). When the freezer is set to a low enough temperature, you will find that even 14 minutes is plenty of time to acheive the desired ice cream consistency in the ICE-45 (without having to pre-chill the ingredients).
Other things to check:
Make sure you are using heavy whipping cream and not half-and-half or other substitute.
Make sure that you wait until you are ready to pour the ingredients into the bowl BEFORE taking the bowl out of the freezer.
Aug 18, 2009 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Kenmore 64802 Top Freezer Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
