Question about Frigidaire FEF336BC Electric Kitchen Range
I have a stove and it is frigidaire and it the bottom drawer back clips fell out and it just drops when I close it how do I put the clips back in
Just happened to us and my wife figured it out. They go on the bottom of the side panels of the drawer at the back. The hook part sticks inside the drawer.
Posted on Mar 16, 2011
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
How do i find model # for my frigidaire electric stove?
Hey friend, that's a great question!
Typically you can locate the serial tag (which lists your model number) on the bottom drawer of your range. Hopefully this information is helpful and if you need any additional assistance please feel free to reach back out. -Matt
Sep 29, 2014 | Frigidaire Kitchen Ranges
Whirlpool stove
You should be able to just pull the drawer out and reach in and grab what ever was dropped . I have yet to find a stove that you can not either access from the front or by pulling the stove out and get in behind . If you have to pull it out make sure you just pull straight out try not to turn the stove you will find that it will pull out very easy and there should be enough length in power cord to allow this
Dec 28, 2013 | Ovens
My Frigidaire 30" gas stove is not leveled from
If you remove the bottom of the range, where the pan storage drawer is, you will see the leveling legs there, and you can use those to level the machine. Don't use pliers if you can avoid it, find an adjustable wrench or an open end wrench, the ones on mine are 7/16th. You can use a measuring cup filled to a line level, and place it on the stove as you move the legs, then you can better adjust them. Do so until the water levels off at the line you filled to. A final test will be to place a flat pan and only drop a couple drops onto it, and see if this runs to one side or the other.
Hope this helps, Please rate and comment, Thank You
Joe
Sep 17, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Levers on side of stove
They are for removing the drawer from the cabinet.
Charlie
Aug 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool electrice stove storage drawer
There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
Nov 22, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire oven heating elements **** the bed
open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
Mar 30, 2008 | Kitchen Ranges
Magnet
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
Sep 04, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FEF336BC Electric Kitchen Range Logo
485 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
