Question about Eidos Interactive Gangsters 2 for Windows
I have the CD Gangster 2 but when I try to download the game I get an error extracting support files Data Error (Cyclic Redundancy Check) I used to play this game on my old computer it worked fine both are XP systems EIDOS
2 Suggested Answers
  • 27 Answers
SOURCE: Lego star wars I installed perfectly, played for a
you should try and uninstall it then reinstall it.
Posted on Sep 26, 2009
Tip
The NASTY "CRC" Error ......Tackle IT
What does CRC(Cyclic Redundancy Check “error”) mean?
There are plenty of technical resources on the Web that discuss cyclic redundancy checks (CRCs). Most times you won't need to worry about this technobabble. That is, until one it day it suddenly appears and you think - what the hell does that mean? In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear.
The most common time you will see the cyclic redundancy check error message is when trying to read data from a damaged CD or DVD. Just before it appears, your CD/DVD drive will probably grind and whirl away - your PC may also become a little slugglish.
Less frequent causes are the result of system crashes, and buggy software (hello Microsoft), incomplete downloads (often identified by the misleading message 'This is not a valid Windows file', 'This is not a valid win32 application' or 'Corrupt Zip file'). If this problem happens frequently with downloads, try using a download manager.
For CDs and DVDs, the problem is a little different. Normally, when CD/DVD drives get a CRC message from a disc, they try to read the disc again - hence the grinding sound. After several failed attempts, they give up and display the redundancy check error. The problem can be hardware (loose cables, failing drive), software or damaged media. In most cases checking and cleaning the disc is the easiest way to overcome the problem. If different clean discs produce the same error, it is likely to be a hardware issue (check the discs in another drive). Another common cause of these errors is poorly burnt CDs and DVDs - especially those that had numerous or severe buffer underuns. USB burners suffer from this problem when the burn speed is too high (generally above 4X-8X)
If the discs are damaged, you'll probably need a recovery tool to get back your data. CDCheck 3 will work for CDs and DVDs. First it will check the media, and then you have the option to recover the files. It's free for personal use and has saved many people heartache when it comes to recovering lost digital images and videos from damaged CDs.
on Dec 22, 2009 | Computers & Internet
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
We have been given the PC game V8 Challenge, but am unable to install the game. It installs to 88% then says: "Data Error (cyclic redundancy check)". Please can you advise as to how we get thte...
a Data Error (cyclic redundancy check), is usually a problem with the CD, is the CD dirty? you might try cleaning it, (you can pick up a CD cleaning kit at Walmart for $5). Or you might have a problem with your CD drive
Jan 04, 2011 | Computers & Internet
Cannot Copy File:Data error (cyclic redundancy check).
Try to download" Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Thanks
Mar 01, 2009 | Computers & Internet
Cyclic redundancy check error
Trying Downloading Quick Install for the WUSB300N from
www.linksys.com
Feb 29, 2008 | Linksys WUSB300N Wireless Adapter
It sounds as if the install software is corrupted.
Download a new copy and try again.
The Linksys download page is here.
http://www-uk.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=UK%2FLayout&cid=1129319214507&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1450714507L02
Hope this helps!
Matt
I am trying to install the Camedia Master software into a new pc, but when the disk gets to 90% loaded it freezes.
A CRC error (Cyclic Redundancy Check) is a data corruption error. This basically means that the data read from the media did not match what was expected to be read by the software. I would say that it is most likely that the source media that you are copying/reading from is corrupted. It is also possible that the destination media that you are copying to could be the source of the problem. If it is a hard drive try running scan disk or other disk repair software, if it is a CD - clean or replace the CD. David Millier Advance Camera Repair
Feb 25, 2007 | Olympus Camedia C-350 Digital Camera
Eidos Interactive Gangsters 2 for Windows Logo
Top Eidos Interactive Video Game Consoles & Games Experts
Hanzu
Michael Vincent Cruz
James Wishart
Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
