Question about Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum
I need the replacement part that inserts into the working end that had the brush attachment. Can this be purchased anywhere?
  • bobcush2 Jan 01, 2011
    I asked for where one might be able to buy parts for a Sharper Image Steam Wizard and was directed to an ebay post to buy an entire replacement. What would I do with the one I have? Throw it away because it needs one small part? I need to know if it is possible to get any parts or attachments.
  • bobcush2 Jan 12, 2011
    The customer service number that you gave me connects you to the "new" Sharper Image, a company that bought the rights to use the name and web site out of bankruptcy. They said that they have no connection with any product bought from the original company. Any other ideas?
I need replacement brush
DO A WEB SEARCH FOR THE MAKE AND MODEL OF YOUR VACUUM CLEANER AND ADD THE WORD SPARES TOO, THE SEARCH ENGINES WILL THROW UP A NUMBER OF RESULTS FOR YOU TO CHOOSE FROM.
yOU CAN ALSO ADD THE AREA YOU LIVE IN TO GET SUPPLIERS NEAR YOUR HOME. All you then need to do is place an order, parts are usually delivered within a number of days
Jul 12, 2015 | Vacuums
How can I get the brush roller to work
HI, it's Jim from Crucial Vacuum!
First things first, unplug your vacuum and turn it over. Check your brush roll for any large amount of debris. This usually comes in the form of carpet fibers, or hair strands wrapped around the brush roll. Try manually rotating the brush roll, this will help unclog any hidden debris.
Take off your vacuums bottom plate, this is usually held on by two screws on opposing sides of the bottom of your vacuum. Remove the brush roll and examine the belt to see if it is applying tension to the brush roll. If the belt is loose this would cause the brush roll to not work properly.
What's the quality of the bristles on the roll? If they look worn down, or loose then it's time to replace the brush roll itself.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Jan 28, 2015 | Vacuums
Can the Turbo Brush on a Bissell vacuum be repaired?
Hey Teri! If you have good suction from the end of the upholstery hose, the turbobrush should rotate as long as there isn't anything binding the brush. Otherwise, a new turbobrush will need to be purchased.
Here's a quick link to ordering one online.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2433&st=2&cid=ccsocial
Feb 02, 2013 | Vacuums
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
The brush attachment always slows when it hits carpet. I've replaced belts and it just doesn't do what its supposed to. I doesn't seem to work very well. If the brush isn't moving how could it move the...
One thing you might want to try is to see if the brush itself is binding up at the ends. When dirt gets in the end pieces and makes the brush difficult to spin, it will slow down, add to that the contact with the carpet and it may slow down even more. Give the brush and axle a good cleaning to see if it works better. Add a bit of WD40 to the ends of the brush axle.
Oct 04, 2010 | Filter Queen Majestic Canister Vacuum
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Great hose suction, awful floor performance
Lose of suction usually means a clog either in the hose, dirt inlet by the brush roll and clogged filters. But a belt that has stretched to where it won't turn the brush roll under load will make it appear as no suction. If you have replaced the belt in a while, I would try that.
Apr 24, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Hoover steamvac clean surge turbo power 5200 attachment problems
That part to install in tank, is at the end of your hose. Take the lide off of the dirty water tank, on the front of the tank, there is a block that will slide out, then you can insert that part in its place. You have to have suction to make the brushes spin, so you just need to put the block on the end of the hose in the slot on the front of the tank. When down however, put that block you took out back, or your cleaner won't work right.
Jan 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Replacing belt but where is the motor shaft
the shaft of the motor might be through the hosing on the under side of the vac where the brush is. give me the model #
Dec 18, 2007 | Hoover U6476-900 WindTunnel Vacuum
Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum Logo
132 people viewed this question
Top Sharper Image Vacuums Experts
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
