Question about Refrigerators
I bought a Kelvinator fridge in July which seems to run constantly, it has now been relegated to the garage, whats the problem? It is model No KTM 4200WB
    Champion:
  • 239 Answers
Most refrigerators have about a 70% duty cycle, depending on ambient room temperature, content, etc. If your unit is indeed running all the time as you state, it may be low on refrigerant, have an inefficient compressor, or an air flow issue. Make sure there is no frost buildup in the freezer, the fans are running, door seals are good. If all above looks good and the temps are ok, you may just be catching it on a cycle on time and not noticing it cycling on and off, especially it being in the garage. If the temps are questionable, my money is on low refrigerant level.
Posted on Dec 29, 2010
What is the correct setting for a kelvinator fridge freezer
mine has 5 setting, i dont know what model you have but i set mine on 3 and it keeps everything frozen, you may have to experiment as to what setting you like to have it
Nov 24, 2013 | Kelvinator Freezers
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Kelvinator c302f-r fridge is freezing everthing
sounds like thermostat if its non frost free model,otherwise it is temp sensor.need model number to clarify.
Apr 25, 2012 | Kelvinator Refrigerators
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator Opal CS 390 F door has dropped down on handle side.
My sister has the same fridge model. We've removed the door and the bottom bracket supporting the hinge had collapsed up inside the door. We're going to cut out a piece of steel (3-4mm thick) and glue it along the bottom of the door in order for the door hinge to insert into something solid. Looks like it's a weak point in the door construction. Pity Kelvinator wouldn't acknowledge the problem and come up with a solution (other than replacing the door at $340 - which is what we were quoted).
Apr 26, 2009 | Refrigerators
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
Jan 20, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
