Question about Sony BRAVIA KDL-46V3000 Television
Sony klv32d300a lcd screen has vertical colored line sound is fine.
hawkwatcher
  • 67 Answers
SOURCE: Zenith LCD Flat Screen TV just shows vertical lines of color
Press menu button on the TV if the on screen display is also distorted or no pic the TV is definetely defective. You can try unpluuging from wall for about 15 minutes and see if reset helps if not problem is either main p.c.b , LCD panel , LVDS cable or Power supply board. and would require service. most likely problem would be bad connection at or defective LVDS cable that connects main p.c.b to Panel (cheapest fix) or defective main p.c.b. If it is the panel it would probably not be worth repairing and you may want to sell as is on ebay.
Posted on Jan 13, 2008
  • 718 Answers
SOURCE: On my LCD TV. a series of vertical colored lines
First you can try adjusting the cable to the LCD Controller (LCD CONTROLLER 6870C-0080D from LG 42LC2D) Sometimes the contacts get out of alignment and disconnecting/reconnecting it will clear it up. Do not touch the contact points.
If this does not work, you may have to replace it.
Posted on Mar 14, 2009
SOURCE: Vertical color lines on my Sharp LCD monitor
try pulging the wire out and back in should fix the problem
Posted on Mar 26, 2009
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
SOURCE: different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Posted on Sep 10, 2009
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
What board is defective on a sony bravia KDL-XBR6 that has a colored vertical lines on the whole screen? No pictures on screen an its just a colored vertical lines...
T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 05, 2015 | Sony BRAVIA KDL-52XBR6 LCD TV
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
I have vertical lines on my screen
Single colored, pencil-thin? If they stay same place when switch to HD channel and back, It's bad LCD panel. Expensive.
Apr 20, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Oct 04, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 40 inch lcd television
Call Sony!! It Will get worse!!! The panel has ribbons that have fine wires that are used to show each line of information on the screen. Either the panel is going or the wires are loose. Either way, the panel needs replacing. Just hope to God it's under warranty or if not, sony will help you out with a buy-out.
Aug 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Verticle lines following the color spectrum across the screen.
Had Sony KDF-E50A10 that had the same line problems after 16 months. Was fine at lunch time and when got home from work and turned it on, they were the lines. Want over $800 to fix it. Told me it was the B-Board assembly. Sony was no help. They have exteneded the warrenty on another part that works along with the B-Board but not just the B-Board itself, so probably not any more Sonys. I'm going with LCD now.
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Sony BRAVIA  KDL-46V3000 Television Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
