Question about Microsoft Wireless Mobile Mouse 3000
I have a 5000 mouse rubber on the wheel has stretched badly, need to replace, can I get this part or have it repaired, approx costs please.
3 Suggested Answers
MSG-CPC
  • 1325 Answers
SOURCE: The mouse wheel on my wireless mouse 5000 is not
its time to replace the battery in it !
post positive feedback please
Posted on Oct 17, 2010
If the mouse is otherwise working, it may be dust. Mine is Microsoft 3000 and I just squirted compressed air into the gaps either side of the wheel. It had not been scrolling for weeks; now it's fine.
Posted on Apr 04, 2015
Microsoft 800 wireless. How do I disassemble and clean?
How to open microsoft wireless mouse 800 - YouTube
? 3:06
https://www.youtube.com/watch?v=ptrvp9Vjz8g
Aug 25, 2013 - Uploaded by rabb able
This video is about if ur mouse left click is not working or hard clicking for use then this is simple way to open ...
Microsoft Wireless Mouse 5000 disassembly - YouTube
? 0:53
https://www.youtube.com/watch?v=vnU3xYoxcSo
Jan 31, 2012 - Uploaded by keroronsk
Microsoft Wireless Mouse 5000 disassembly ... to get to my scroll wheel...the dang thing's rubber seal has detached and I can't scroll anymore.
Microsoft Wireless Mouse 800 Teardown/Disassembly ...
? 3:35
https://www.youtube.com/watch?v=_I4n-WM3nh8
Mar 21, 2015 - Uploaded by Shin2_D
Microsoft Wireless Mouse 800 Teardown/Disassembly ... [Quick tips] Simple way clean your Android Wear LG Gwatch - Duration: 1:05. by ...
How to disassemble Microsoft Wireless Mobile Mouse 1000 ...
Dec 12, 2015 | Computers & Internet
WHEN I TRY TO SCROLL WITH MOUSE THE SCROLL BAR AUTOMATICALLY MOVES UP AND DOWN
Sounds like the wheel switch on top of the mouse is stuck in the "on" position. Pick up another mouse at computer store and try it. If that fixes it, great. Just as cost effective as trying to repair the bad one (good luck finding the tiny wheel switch).
Dec 24, 2014 | Computers & Internet
Cleaning the Microsoft Wireless Mobile Mouse 4000
I disassembled my Microsoft Wireless Mobile Mouse 4000.
You need a set of precision screwdrivers to do this.
1. Peel up the teflon pad on the bottom of the mouse with a flat head screwdriver. Leave the other (the one under your fingertips) alone.
2. That will reveal a tiny silver screw. Remove that and then lift the gray upper section up from the back, then pull it free by moving it toward the back. The clips up at the front go in a forward direction, but they are not clipped in. You could just shake it free.
3. There are 4 tiny black screws. 2 at the front and 2 at the back. Remove them.
4. Use a flathead screwdriver to pry the retainer clip from the back of the mouse. It's just held on by a couple of little nubs. Don't break it. Be gentle with this part.
5. Now, the mouse can come apart. You need to pull the bottom of it free at the back and then slide the entire bottom section back. There is a little piece of circuit board that sticks out underneath the right-click area that will get hung up on the upper shell if you try to pull it straight down. This will take a little bit of prying since it's all clipped together, but it will come loose.
That's it. I didn't take any of the inner parts apart after that. I will say that my sticky scroll wheel was scraping against the upper shell. By loosening the two screws at the front, it relieved some pressure and let it run more smoothly. I didn't actually have to take it all apart after step 2 in order to fix that issue.
Mar 08, 2012 | Microsoft Wireless Optical Notebook Mouse...
PLEASE HELP please help 2006 yamaha yzf600r i have a problem ..... around 5000 rpm i get little tingeling vibrstions in the foot pegs handle bars and sometime in the tank i guess it like buzzing 5000...
Hi, Krisloba and the usual suspects are:
1. Wheels and or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain is badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect due to a poorly tuned engine.
7. Internal engine problem flywheels have shifted.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Reduce engine vibration
Bad vibration between 5000 5500 RPM Smooth before and smooth after is this...
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Jul 20, 2011 | 1999 Yamaha YZF 600 R thunder cat
Approx. 10-20 % "drift or
Swaybar links are probably broken. There is one at each control arm (A arm) Behind the wheels. The bar stretches accross the car. And the links bolt to the bar and control arms. The links are long bolts About 4 inches, with four rubber bushings and four metal caps
Feb 19, 2011 | Oldsmobile Silhouette Cars & Trucks
Rubber drive band snapped and took out a earth and grey wire, can it be repaired? approx. how much?
any electrician should be able to repair this if you have the machine's cover off;
In fact you could do it yourself with a soldering iroin to replace the spade bit on the wire and some shrink rubber tubing which will allow you to join in any extra wire.
Cost to fix about $10 DIY and $50 by Mr Fixit type
Please rate my help++++Thanks for using FIXYA
May 31, 2010 | Zanussi FJD1266W Front Load Washer
Disc tray will not open
on dvd players
power supply to moter which is controlled by tiny rubber band which is ether broke or stretched and needs replacing
sorry
Sep 19, 2009 | Sanyo DVW-5000 DVD Player/VCR
Scroll wheel stopped turning, seems to be hanging up due to an alignment problem. How can I open it to take a look inside?
If your scroll wheel turns but you don't feel the 'notches' it is most likely stripped. I've repaired my Logitech, and based on what I saw inside, I doubt that it's an alignment issue.
If it's stripped, and the hexagonal end of the wheel's axle that fits into the receptor has lost its hex shape, I have a perfect fix.
I tried gluing it, but that only lasted as long as the glue. What I did instead was remove the wheel, thread a thin rubber band through the receptor, pull the rubber band tight and then reinstall the wheel. Once tension on the rubber band was released, it expanded again, making a tight friction fit of the wheel's axle and the receptor.
Hope that helps.
May 09, 2009 | Microsoft ARC Mouse
Microsoft notebook mouse 5000 Wheel scroll stopped
Fixing the wheel/scroll malfunction was as simple as a reboot. I usually shut down in hibernate. Apparently the system needed a complete reboot to reset.
Thank you for following up.
Nov 22, 2008 | Microsoft Wireless Laser Mouse 5000
Microsoft  Wireless Mobile Mouse 3000  Logo
421 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
