Question about Baby Gear
Hi I was given a second hand Apollo by Swallow Pram and I can't figure out how to fold it. Is there an online manual?
SOURCE: help me fold this pram chassis please
I had this same problem with a tag sale PegPerego Tender stroller. If its like mine you push the red button on the handle and twist it, and then step on the gray level on the lower left side near the hinge,
Posted on Jan 12, 2008
SOURCE: Handle will not fold down any more
We hand handle problems, and no receipt. I just called bugaboo with a serial number and they sent a new chassy.
Posted on Apr 27, 2008
SOURCE: how do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Posted on Jun 14, 2008
SOURCE: Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
Posted on Feb 18, 2009
janrom2321
  • 74 Answers
SOURCE: folding and unfolding stroller/ how to adjust stroller seat?
if you place your hands on either side of the stroller keeping your hands on the side of the handle at the same time pull uo and that rfolds and unfolds stroller
Posted on Sep 13, 2009
Hi i need instructions on how to collapse the obaby apex double pushchair? please help me!!!
hi not sure if these will help they are from the apollo version most double buggies fold tthe same
just double check with images if they look the same then these will work
http://www.obaby.co.uk/manuals/Apollo-Plus-Instructions-web.pdf
Feb 07, 2011 | Toys
Can't fold pram
Hi, I believe you activate the folding mechanism by pushing down on the two grey rectangular plastic buttons on the black side hubs (at the mid point of the pram).
In any case you can download the complete instruction manual for the pram for free at http://www.freebabymanuals.com/quinny/prams
Hope that helps.
May 26, 2010 | Quinny Buzz Jogger
Hi, just bought a 2nd hand icoo pico 4 but cant fold it down. ive tried pulling the lever (with the arrow on) up but nothings happening! can anyone help ...please. thanks!
turn the front wheels facing each other and lock them... them there is a black handle thing on the left side of the handle bars.. pull that up and push the handle bars down at the same time
Feb 23, 2010 | Hauck I'coo Pico 4 Pushchair Travel System...
Folding and unfolding stroller/ how to adjust stroller seat?
Sep 11, 2009 | Quinny Freestyle 3 XL Stroller
How do i fold down the mutsy urban rider pushchair
To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
Jul 04, 2009 | Baby Gear
I cannot close milano stroller
Above the wheels at the rear of pram there are small levers that you must activate. I'm pretty sure you press the left one first (do not need to hold down) then hold down the opposite side's lever and push forward and down on the handle of the pram. If this doesn't work try pressing the levers in the opposite way first. Originally the pram would have had stickers "1" and "2" on the levers to dirict you how to fold. If in Oz look up Karisles on google and follow the prompts to download instruction manual.
May 28, 2009 | Peg Perego Milano XL Stroller
Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
Apr 09, 2009 | Quinny Buzz Jogger
2nd hand BEBEcar Adventure raider AT+
Hi, I have just bought second hand the exact same pram. You have to push in the red button in the middle of the handle, then turn the handle down towards the floor. By putting a little pressure on it it should now start to fold down. Hope this helps.
I have my own dilemma though. When the carry cot is on as a forward facing pram, does the seat unit come off that you use for the buggy?
Apr 17, 2008 | Bebecar Raider AT Stroller
Bertini M5 Shuttle
hi I think I could help I bought a bertini shuttle as well if you stand behind the pram on the right run your hand down the right side of the hood there is a push up lever there mine is grey ok you need to push the grey? lever but also on the left and right there is a black lever you must push up al together hope this helps good luck from debbie
Jan 09, 2008 | Bertini M5 - TS City Stroller
Nov 25, 2007 | Bugaboo Gecko Stroller
Baby Gear Logo
305 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
