Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
System registry problem & speed related problem
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
structure.
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
Acer 5535 freezing
If your computer freezes,then the problem is related to the registry. When the Windows registry is filled with errors it can't stop your system from properly communicating information.
The only solution for freezing is to clean the registry of corrupt files and various errors. Not only will this prevent computer crashing, it will also speed up your system considerably.
Get technical assistance here if still the same problem is occurring....http://www.vtechsquad.com/windows-repair/
Aug 10, 2012 | Acer Aspire 5535-5050 Notebook
Cityville doesn't load right; makes half pages, slow hangs & won't post
2 things to look at 1st, do you have the latest version of Flash on your computer. 2nd how is your
connection do you have good connection speeds. Also run your virus/antispyware software and
check your system. If you don't have one of these check out Adaware by Lavasoft.
May 19, 2011 | Facebook Social Network
My acer 5920 laptop freezes when I click shutdown and it just freezes as windows is shutting down. I have installed windows xp sp2.
Jan 20, 2011 | Acer Aspire 5920-6727 Notebook
Hi everyone, ok while playing game... suddenly it crashes.. & got a pop-up showing some registries corrupted need to restart..& after that i m not able to play my games...when i start them pop-up...
The registry is a very important part of Operating Systems like Vista. You need a good registry repair and cleaning software, I suggest you use the software from the following web link. The software is called Wise registry Cleaner. I am suggesting this software because it is free there are many other more powerful software in the market but they will cost you.
http://www.wisecleaner.com/
If this registry cleaner software fixes your problem that is well and good but in case the problem lingers on you have to at least reinstall your games but problems similar to this will carry on as I anticipate your computer may be critically infected with viruses and malware therefore I suggest that you get a fresh reinstall of Windows and reinstall your Games one by one for best results.
Good Luck!
Aug 19, 2010 | Microsoft Windows Vista Ultimate Edition
My computer is running way to slow
You need to provide more details...
Anyway, adding RAM is the first and most effective method to speed up slow computer.
Then, run the disk cleanup and disk defragmenter to free up disk space and speed up program responsiveness.
Lastly, run a registry optimizer software, clean and defrag registry.
Dec 07, 2009 | Webroot Spy Sweeper (spysweeper) for PC
How to fix registry error 142 free
Use Regeasy Cleaner(15-day trial) or Registry Easy 5.6 for Windows(15-day trial) to clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. Download it at following links:
http://www.versionhunter.com/windows/System/System_Miscellaneous/regeasy-cleaner.html
http://www.versionhunter.com/windows/Tweak/Registry_Tweak/registry-easy-56-for-windows.html
Nov 24, 2009 | Computers & Internet
I HAVE a brotherMFC 420 CN and I can send faxes but not recieve. I use to be able to recieve untile I tried to speed up my computer and installed a registry cleaner
There ya go...you corrupter the registry and that directly relates to how eveything on the computer operates.
Do a system restore back to a point before the registry changes, or uninstall and reinstall your 420cn
Nov 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
212 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
