Question about Waring CO1500 1700 Watts Toaster Oven with Convection Cooking
Stopped working, temperature not heating - Waring CO1500 1700 Watts Toaster Oven with Convection Cooking
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Top heating bars stopped working
Dear Tang_Tuong,
I would check all of the fuses, the internal fuses and wiring for any signs of damage and that particularly from heat. Also multimeter the connectors of the wiring to the element and see if you are getting a voltage reading, if you get a reading from the wiring and the element is not heating up, then you need to replace that element, do these checks for all of the internal components and you will find the one at fault.
I do hope this is the fixya for you and look forward to hearing how you get on.
Yours sincerely
Ouszen
Feb 07, 2012 | Euro-Pro Toaster Ovens
When the oven is on for a couple of min. it makes a bang sound
Probably is the metal heating up and expanding. Does everything still work? Your not smelling any smoke are you. If it still works fine and your not seeing any smoke or smelling anything burning it probably is OK. Does it do this everytime you use it? The sheet metal on the outside and inside can expand and if it is crimped at all it will make a noise when it heats up and expands. I hear this a lot where I work, we deal with extreme temperatures and when metal heats up it expands and pops sometimes!
Nov 15, 2010 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
    it is several prosibilites for your problem:
    1) the wire of the oven is damaged;
    2) the thermostat is decalibrated or damaged;
    3) one or more heating element is intrerupted or burned.
    solution's:
    1) check the wire an replace or repair where is posible whit similar heat resistant wire;
    2) replace the thermostat whit similar one;
    3) replace the heating element
    Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
    Rival to606 temperature control doesnt work, unit doesnt heat up
    The heating bar or element needs replacement.you can find it in electrical shop or electronic and electrical supplies in your area.
    If you find this answer helpful, kindly vote it.
    Nov 09, 2009 | Rival TO606 1500 Watts Toaster Oven with...
    Oven does not cook at temperature set at. 2 hrs.
    Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
    Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Will not heat up
    replaced the cord
    Apr 05, 2009 | Oster Toaster Ovens
    Model 460/5 can not control the heat
    I would have to say that your issue is thermostat related.  The thermostat only send a signal when temperature is reached, not what the current temperature is.  So if it is malfuntioning, the desired temperature will never be reached.  Therefore, not sending a signal to cut the heat, even though it is 350.
    Mar 04, 2009 | Farberware T490C 1500 Watts Toaster Oven...
    Krups Toaster Oven elements stopped heating up
    this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
    Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
    Waring CO1500 1700 Watts Toaster Oven with Convection Cooking Logo
    57 people viewed this question
    Top Waring Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Waring Toaster Oven Expert? Answer questions, earn points and help others
