Question about Sony XAV-W1 Car DVD Player
After ejecting my dvd, the cover is not closed back automaically. Is there anyway i can close it back?
  • 2 more comments
  • sbgoh79 Dec 29, 2010
    Tried using your proposed method and still can't close. Not sure whether there is anything in the way that prevent the cover from closing... Anyway to check?
    i hav used the methods you suggested previously and not able to close it. Is there anything that can cause it to be stucked??
  • sbgoh79 Dec 31, 2010
    I have managed to close the cover manually but
    The screen keep showing "panel open".
    The cd eject button is not usable
  • sbgoh79 Jan 16, 2011
    Is this all I got for paying 6 buck!! The problem Is not resolves yet!
  • Sony Master
  • 4,924 Answers
Maybe its stuck ..or you powered it off by switching the key off...Try to power it up ...and insert another disk ..and see if it shuts the cover when the disk inserted..if after you get the disk out the cover is not closing try to close it manually once that you insert the disk ...Kinda doing the operation in the same time it should do it ...maybe there is something in the way ..
Posted on Dec 29, 2010
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
How do I open and close my dvd player using the remote control
This Model doesn't have an Eject Function on the Remote Control.
They work on the principal that if you're changing the DVD then you'll be by the Player anyway to use that Eject Button.
Jun 03, 2011 | Sony DVP-SR500H DVD Player
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
I nudged the loading tray with my foot when changing a disc. As a result the tray is not opening or closing, presumably because it is no longer aligned properly. Is this likely to be something I might fix...
Mechanical timing and alignment is the problem of your dvd player.
This comes when you accidentally force the disc tray to close.
You need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand.
Make sure that the cd loader reaches the limit switch before it closes. This will return back the right timing and alignment.
Feb 04, 2011 | Denon DVD-1930CI DVD Player
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
DVD side will not open, for the longest I could only get the DVD side to open if there was a disk in the slide yesterday the DVD side was closed with NO disk in it and now I can not open it
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. If this doesn't open the unit, you will have to unplug the unit and remove the cover. The cover is held in place by two silver screws on each side and five silver screws on the back of the unit. Once the cover screws have been removed, you can slide the cover towards the back halfway and then take the silver cover (held in place with two screws) off of the DVD player. Once the DVD cover is removed, insert a disc in the player and re-install the dvd cover and case cover. Plug the unit back in and eject and close the cover like normal. I have never tried to remove the magnet from the cover and checked to see if the DVD player still worked correctly. I have found it easier to just leave a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Apr 09, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd will not eject from jvc hr xvc27u dvd player all it will do is display the word read on the screen
elsombro is right. There is a little whitish plastic square on the right side of the player, part of the DVD assembly (after you take off the cover). It's about 1/4 inch square. With the unit turned on, push that square with a pen about 3/4 of an inch in or as far as it will go. There will be a clunking sound but that is the sound of the DVD being released back onto the tray. Now gently push the back of the tray forward, ejecting the disk manually. Take the disk out and then press the close button. If the door doesn't close, it's out too far so manually push it in about an inch or so and then press the close button again. Should be fine after that. I think my problem was a DVD I recorded on my computer and it has the wrong format or something. After I got it out I put a regular DVD back in and everything was fine.
Dec 30, 2009 | JVC HR-XVC27U DVD Player/VCR
Playing a dvd
I'm having a similar issue....I load a DVD and the player goes thru the normal cycle and just when you think you here the DVD start to spin...is cycles again and ejects and closes half way then powers off? I took off the cover (like I know what I'm doing) and figured that the leverage gear which raises the laser to the turn pad thing isnt getting acctuated....? I cant figure out what makes that gear turn..there is nothing really toughing it gear or spring? anyways I'm looking for a solution myself.
Jan 07, 2008 | Televison & Video
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Sony XAV-W1 Car DVD Player Logo
67 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
