Question about Logitech Pure-Fi Express Plus Omnidirectional Speaker Dock Remote Control for iPod and iPhone
Logitech Pure-Fi express plus clock doesnt work and is frozen at the time i set it to. i have tried unplugging and reseting but nothing works have also tried in 12 hour setting that doesnt work either
IrishDruid
  • 2712 Answers
SOURCE: Changing the time
Here is a link to the manual:
PureFiElite_QSG_AMR.pdf
Table 6 in the guide explains the procedure to setup the clock.
Hope that helps. Kindly rate the solution if you found it helpful.
Cheers!
IrishDruid
Posted on Jun 25, 2009
SOURCE: Change Clock - Logitech Pure-Fi Elite
Here are the instructions from the User's Guide for the Logitech Pure-Fi Elite Audiostation/iPOD Dock:
To activate the large clock display while the Audiostation is on:
1. Tap "select" several times - until the large clock display appears.
To set the current time:
1. Turn Audiostation on. (OK I'm good so far)
2. Tap "select" several times - until the large clock display appears. (If you have previously set the time and are "changing " the time, this is the default display, so just skip this part)
3. Press and hold "select" until "clock setting" appears. (It takes 3 seconds and my unit displayed the "12 or 24? " screen instead of "clock setting". )
4. Use the Up/Dn arrows to change the time. Use "select" to accept the changes.
Here's the Quick & Dirty:
I assume you use it as a clock so the time is already displayed. Turn the unit on.
Press and Hold "select" until "set time" appears.
Press "select" again to next screen, (12 or 24 hr?)
Press "select" again for the hour, and soforth.
Use the Up/Dn arrows to adjust the units.
Posted on Feb 18, 2010
award462
  • 395 Answers
SOURCE: Need Logitech Pure-Fi Elite users manual
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
SOURCE: How to open the pure-fi anywhere 2 (Logitech)so th...
I just got my Pure-Fi Anywhere (must be "1," because it doesn't say "2" on the box.) apart to both replace the battery (Ebay, $12-$15), and tighten the screw on the swivel leg.
1) Don't use a screwdriver or anything steel - you'll bugar up the plastic if you do. I used the plastic "prying tools" that came with the battery replacement kit for my iPod. I...
2) Wedged in pretty hard behind the faceplate that encircles all four speakers. This faceplate is about .080" thin. Once I saw that I could force these plastic tools in there, I carefully slid them around and loosened the whole plate. This plate is stuck on with, I guess, some kind of glue - but it remains sticky. I haven't reassembled anything yet, but I think it will go back on and stick again (careful where you set it).
3) Removing this thin plate reveals a bunch of screws. You only need to remove the eight black (larger) screws (ignore the six silver (smaller, flathead) screws - they don't need to come out).
4) Now for more prying (you got those eight larger screws out, right??) - I used the same plastic "prying tools." The best spot for this turned out to be: a) on the top; b) the side OPPOSITE of all the control buttons (power, volume, shuffle, etc.) -- halfway between the middle (iPod cradle) and the end (the opening is about 1/2" back from the front of the speakers. I forced the plastic tool in there, then twisted it and the two pieces seperated (with some effort)(you did remove those screws, right?). I worked the plastic prying tool around CAREFULLY, and eventually had complete success in seperating these two pieces. The wires from the battery are the only thing now connecting the two pieces together.
If you went this far, you don't need me to tell you about the battery or how to tighten the feet. But I DO want to express my irritation at the "expert" at the Logitech forum site: He told a questioner that "you don't want to open up the speakers, it will reduce the acoustics if you do..." Again, if you've gone this far, you can see that nothing done here could have anymore adverse affect on the acoustics than opening your car's trunk would affect the car speakers in the back.
Posted on Sep 12, 2010
jyackle5
  • 8197 Answers
SOURCE: cannot operate--need manual for logitech pure-fi
You can get the manual on the link below. Scroll down to product details to download it.
http://www.amazon.com/Logitech-Pure-Fi-Express-Omnidirectional-Speaker/dp/B001FWXDZQ
Posted on Feb 05, 2011
How to set time on iPod dock model S00067
The manual can be downloaded from the Logitech Website. The link at the bottom of this post is where the manual can be found for your unit or click on this link (you need Adobe Reader to view it which can be downloaded for free)
http://logitech-en-emea.custhelp.com/ci/fattach/get/502116//session/L2F2LzEvc2lkL21ReUpSR0Fr
Logitech Pure-Fi express Plus page:
http://logitech-en-emea.custhelp.com/app/answers/detail/a_id/10300/section/troubleshoot/crid/439/lt_product_id/4781/tabs/1,3,2,5/cl/gb,en/kw/
To set the clock as per above manual:
1. Press and hold the clock set button (the hour will blink)
2. Use control knob to adjust time hours (PM will indicate if not then AM is default)
3. Press clock set button once which will confirm hours and advance to minutes setting (the minutes will blink)
4. Use control knob to adjust minutes
5. Press clock set button once to confirm time set
6. Clock settings now complete
Oct 24, 2013 | Apple iPod touch
How to set Clock for S00067
Aug 04, 2011 | Logitech Pure-Fi Express Portable Speaker...
Logitech pure-fi Anywhere 2 Remote Control not working. Tried a new battery & still not working? any suggestions?
I received my anywhere one week ago, the remote didn't work, reracking several times didn't help, I replaced the battery with minus to plus vv. and then put it in again properly, working flawlessly since. Logitech won't advise this method but it's worth trying.
May 21, 2010 | Logitech 984-000057 Pure-Fi Anywhere 2...
Does the logitech pure fi express take the new ipod nanos
Hi Jod,
The Logitech pure fi express only support Ipod/Iphone up to 3Generation, please note that Iphone 3GS is not currently supported.
Thanks and have a nice day
J -
Oct 26, 2009 | Logitech Pure-Fi Express Portable Speaker...
Remote control buttons won't work
you may have a fualty remote you may want to bring it back theres nothing you can really do
Oct 08, 2009 | Logitech Pure-Fi Express Plus...
Buttons wont work on my logitech pure-fi anytime speakers
I have losted three of the buttons on top off logitech pure-fi go anywhere speakers for ipod
Jun 10, 2009 | Logitech Pure-Fi Anytime Premium Alarm...
hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
Online user manual for pure-fi elite?
You can find the quick start guide on the logitech website but doesn't answer this question. I was needing the same answer. I figured it out after pushing all the buttons, maybe you have by this time tried the same thing.
In case you haven't here is the answer:
there is a little time button (looks like a clock) right above the sleep button on the remote. press and hold this until the time on the display flashes, press plus or minus to move the hours first, then press the play/pause button to switch to minutes and plus or minus to change these. press the little clock button to exit out and set the time.
Hope this helps.
Dec 03, 2008 | Logitech Pure-Fi Elite High Performance...
Logitech Pure-Fi Express Plus Omnidirectional Speaker Dock Remote Control for iPod and iPhone  Logo
116 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
