Question about Siemens WTXD5300US Electric Dryer
Siemens dryer has a extra swishing sound like something got behind the drum
  • 425 Answers
Is your dryer new?
if its isn't then probably that its ball bearings inside is started to end its service life or the belt begins to deteriorate and the drum touches the housing.
if its new, then probably that there is something getting loose inside or some foreign objects get inside the drum (e.g. moneys, pens, etc.).
Posted on Dec 29, 2010
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
The dryer was squeaking when it was on but know it
possible worn bearing.the more wear on the bearing the lower the drum will be.the drum sounds like its rubbing the bottom of the dryer.check for black dust behind the dryer
Feb 20, 2010 | Amana Dryers
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Drum is hard to turn
does your dryer have a plastic glide on the drum or is it on the felt if some one gave you the wrong one that would make your problem worse there is two different types for that dryer
Jan 16, 2007 | Kenmore 83042 Electric Dryer
Sticking drum
YOUR DRUM BEARING HAS GONE
Aug 02, 2006 | Hotpoint WMA30 Front Load Washer
Dryers Logo
243 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
