Question about RCA F36665 36" TV
I have an RCA F36665 36" TV that I'm attempting to fix. The original problem was that it would only click for several seconds when the power button was pressed. I replaced the board P3001 and it now powers up but displays a targer with clear picture in the bullseye, a green ring around the middle, then a blue ring around the outside. Any ideas on how I can fix this? Thanks.
  • Jeff Pearson Dec 29, 2010
    Yes, I'm trying to fix a free TV as a hobby. I'm not sure where I came up with P3001, the correct part number is 247480.
  • RCA Master
  • 19,396 Answers
Hi.
I do not have p3001 in parts list. The only P3001 is wiring harness to controls.
From descriptions it looks like the picture is out of convergence/alignment and deflection is completely gone. Also check the deflection yoke solder joints. I assume that you are doing the repair as DIY repair hobby. A CRT TV in such conditions would not be worth repairing otherwise.
Try replacing the convergence ICS (STK2250). If the problem is not convergence, then have a look at the PIP module. PIP module won't cause the rings. I think problem is deflection.
Here parts for this TV.
Regards.
Ginko.
Posted on Dec 29, 2010
  • Ginko
    Ginko Dec 29, 2010
    Hi.
    P.n. 247480 is the PIP board. That is a problem with this model, the board is often defective.Check that the solder joints in connection to the board you just replaced. Use the Multimeter on Ohms and ensure that there is conductivity. Test flyback transformer and deflection yoke. Test also the horizontal output transistor (HOT).
    The service manual is not available in PDF. Chassis is ctc203cx. SAMS has the manual for sale.
No picture but have sound
That click might have originated in 2 places: either it was the main relay disconnecting or it was the sound of a capacitor popping. Both are very severe problems - they signal that the power source of your tv has just failed.
Fixing it is a job for someone with electronics experience, if you're not one then call a repairman.
Jul 26, 2010 | RCA P42WHD33 42 in. Plasma HDTV
RCA scenium DLP 50''. The blue lights on the front (volume, channel, power, and options) all blink 5 times when I turn it on, but the tv doesn't turn on. It will do this anywhere from a couple of times,...
dear,
tell me, when it goes on then what about the pic on screen.
is it fussy or the perfect..
what happens if you try it again when it normally turns on.. is it still take the same time in the second attempt after sucessful turn on ..
regards,
Aug 08, 2008 | Televison & Video
It wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Jan 20, 2010 | RCA HD56W58 56" HDTV
I have a 52 inch projection TV that takes several attempts to turn on. When it first started having problems, it would turn on after puching the on button about 3 times. Now you have to cycle through about...
Thats the same model as the RCA ITC222 chassis . You can get the CP150, CP114 and CP120 repair kit at www.tvrepairworld.com which should solve that issue. The kit contains the parts and the CD with instructions.
Sep 30, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 in television
You will first have to see if cp150 is puffed up on top then go from there! Also you need to resolder all pinns on FBT poor connections on alot of these sets.HAPPY NEW YEAR!
Dec 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
36"RCA Powers on & off
Biggest problem is IHVT ( HV transformer ) Replace with
RCA original if available.....provide service number off back of set
for part number (s)......T.
Jul 10, 2008 | RCA F36650 36" TV
RCA HD50LPW62AYX2 WILL NOT STAY ON
My HD50LPW62AYX2 RCA TV sometimes reverses the blue and reds. The peoples faces are blue, especially the lips.
Sometimes turning the TV off and then back on again fixes the problem. At other times this correction is good for only a second or two.
Do you have an English owner's manual available on line or otherwise available?
Nov 21, 2007 | Televison & Video
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
RCA F36665 36" TV Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
