Question about Sony VPLEX70 Portable Projector Projector
Lamp/cover blinking - Sony VPLEX70 Portable Projector Projector
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Try this....facing the projector lamp away from your body...theres a part towards your right which might be loose....hit it in to fit hard.....had the same problem got fixed
Posted on Sep 13, 2013
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Posted on Dec 20, 2010
Testimonial: "Thanks! And please tell me where is the lamp cover located."
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Tv Wont Come on 3 red blinks pauses 3 red blinks pauses 3 red blinks
A 3 blink error on this model is saying that your lamp cover is not on properly. Check your lamp cover and door. Make sure they are seated sucurly. If this doesn't fix your problem. Then the switch or little board buy the lamp cover is bad and needs replaced. This is called the T board.
Mar 15, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Sony projector 3LCD lamp/cover blink red
When I plug the LCD the LAMP/COVER flsh blinking red light
May 28, 2012 | Sony Office Equipment & Supplies
hi,
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Replaced lamp. Then I turned it on blinking green light and then yellow. can you help troubleshoot
yellow blinking or not? if blinking your lamp cover is open that could be you forgot to reconnect the wires back to the lead that monitors the lamp. It's a 2 wire molex connector either black or white that will be laying next to that light cover you removed to get to the bub. this connection may be labeled "CD". iF SOLID it is a high temperature indicator, the set would have to have a lamp that works for this, so I'm guessing the lamp hasn't turned on yet. the fast blinking green is your set initializing, testing circuits and fans and yup lamp cover switches.
Dec 11, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Power ligth blinks three times then starts blinking red tv wont start
Lamp cover error, lamp cover is not attached securely. Please check the lamp cover if deformed. If the lamp cover has been deformed due to excessive heat exposure, replace it with a new one. Sometimes the lamp cover melts due to overheating caused by poor air ventilation. Clean the fan and lamp compartment to avoid overheating....
Nov 30, 2010 | Sony KDS-60A2000 60" HDTV
Replaced projection lamp and also cleaned out most of the dust inside the tv. will power on but shuts off before picture comes on tgen three red light blinks. please help asap. thank you.
Three red light blinks shows that lamp cover is not properly closed after lamp replacement. Make sure that the lamp cover is in its proper position. Try to reset the lamp cover and turn it on clockwise direction until you heard a click sound of a micro switch activated by the lamp cover, then put the set on..
Oct 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
Oct 05, 2010 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  1. Remove the outside lamp cover.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit http://www.fixya.com/support/t2631342-need_replace_42_in_sony_wega_hdtv
Aug 11, 2009 | Televison & Video
Sony VPLEX70 Portable Projector Projector Logo
149 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
