Question about Daewoo DV-6T955B DVD Player/VCR
Bad Disc Error
When I insert the disc it searches and then gives a message that states BAD DISC. This just started happening and it happens with any DVD's or CD's. Does anyone have a solution?.....Thank you, Ron Herendeen
  • fred_sccinc Dec 18, 2008
    all discs read BAD DISC.
  • Anonymous Feb 17, 2009
    In my case it seems to be temperature related. When the device was turned off for >= a day discs are loaded, at least for now and play up to some 3 times before the player stutters and shows read problems.
    So I'm thinking it could be failing capacitors somewhere in the DC rails.
    Sergeant:
  • 234 Answers
You want to clean your player lens. with the help of lens cleaner cd! dont use dirty disc inside the player! it spoil the lens!
Posted on Jul 07, 2008
Toshiba 24V4210U tv/dvd "incorrect disc"
Prob has some dust on the lazer if you have a cd player cleaner give that a shot or blow it out really good and give it a shot
Dec 14, 2013 | Televison & Video
Format error on disc on handy camcorder no disc error message
this happens alot with the Sony handycams ... try reading the disc in another DVD then see if you can rescue the recording ... There donst seem to be any other route you can take to correct this ...
Mar 31, 2008 | Canon DC10 DVD Camcorder
Emerson EWR10D5 DVD Recorder/Player - using 16x DVD-R I get an error while recording
Sounds like a bad disc. You may also want to clean the laser lens with a cleaner disc just to be sure.
Sep 07, 2017 | Emerson Televison & Video
My samsung Q45 notebook tells me to insert the windows installation disc and restart my computer. I have not got this, can anyone help?
First disconnect any external devices connected to the computer except the mouse and keyboard.
This error usually happens if the hard drive is not getting detected by the operating system or due to bad hard drive.
First check if all the physical connections to the computer are set correctly.
If it is a laptop remove the laptop battery, wait for 5 minutes and then connect back the battery, check if it works.
If the above step does not work then you will need to run CHKDSK tool to check if there are any bad sectors on the hard drive would suggest running chkdsk which would scan for any bad sectors on the hard drive and if those errors are repairable if would repair and if it cannot at the end of the chkdsk scan you would see a message "found one or more unrecoverable error on the hard drive" which means the hard drive is damaged.
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
1. Insert the installation disc.
2. Restart your computer.
Click the Start button, click the arrow next to the Lock button , and then click Restart.
3. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click command prompt and in the command prompt typechkdsk /f and wait till the scan is completed and later restart the computer and check what happens.
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Important: While performing chkdsk on the hard drive if any bad sectors are found on the hard drive when chkdsk tries to repair that sector if any data available on that might be lost.
Hope this helps!
Jul 09, 2012 | Samsung Q45 Notebook
MY CONSOLE KEEPS SAYING CAN'T READ DISC
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
Aug 20, 2010 | Nintendo Wii Console
Always gives the message bad disc
either the disc motor is not running up the disc speed fast enough,or the laser is burnt out.run it with the cover off and look at the disc speed.it should be about 500rpm
Jan 10, 2010 | Cyberhome CH-DVD 300 DVD Player
Bad disc error message
TRY TO PUT DISC WITH CAR TURNED OFF (ACCS) IF EQUIPMENT ACCEPT DISC, THEN OPTICAL UNIT IS DAMAGED. IF NOT PROBABLY OPTICAL UNIT IS THE CAUSE TOO BUT CAN BE ANOTHER MALFUNCTION WITH THE CD SET
Sep 25, 2009 | 2004 Ford Expedition
Bad disc message Coby DVD-925 B
try buying a cd cleaner with micro brush on the disc, the laser eye may be dirty. That usually helps.....
Apr 12, 2009 | Coby DVD-925 System
Inserted disc reading "No Disc"
Hello Brian,
It looks like you have a bad lens assembly. That explains the "No Disc" error. Just get the lens assembly replaced and it will be back to normal.
Jan 31, 2009 | JVC DR-MV1S DVD Recorder/VCR
Unreadable Disc
Well the same thing happened to me but only on the game Bad company and it only happens on certian maps. I dont know what to do. It might be the game or the disc reader in the Xbox might be screwed up????????
Jul 20, 2008 | Microsoft Xbox 360 Console
Daewoo DV-6T955B DVD Player/VCR Logo
716 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
