Question about Hayward SP3210 15 TriStar Max Rate Pump 15Horse Power
Looking for parts for SP3210Z1MR pool pumps C-Clip ring (2) and also the water pump seal. email suvawala@yahoo.com
  • 77 Answers
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Posted on Apr 28, 2009
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: I cannot get the pump to pump water, motor still works.
Sounds like air has gotten into the pump and froze the pump. It will need to be replaced due to that reason. You can get a repair kit for the pump but it will not be gaurenteed to work
Posted on Jun 02, 2009
protek480
  • 1723 Answers
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
Posted on Jul 03, 2009
john224
  • 1378 Answers
SOURCE: 2 yr old inground pool Hayward pump louder than
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
Posted on Jul 10, 2009
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
Aug 04, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
The pump will come on, but will not circulate the water in the swimming pool. Prior to this, while it would circulate the water, I was loosing water from the pool through the pump.
It appears that one or all of the seals in your pump have failed. Most likely the SHAFT SEAL. purchase and replace the diffuser o-ring, housing o-ring, and the shaft seal. This should do the trick
Jun 09, 2011 | Jandy EPump Variable Speed 20 HP Pump
Water leaking beyween the empellarand moter housing
pool pump repair guy in longwood florida , here to save the day.. Ok what you have is a bad shaft seal (90% of the time) OR tank crack or a cracked seal plate or a bad gasket or o-ring.. look at the link and it wil help you ID your pump and take it apart. prim that pump after a repair !!! www.poolmotorrepair.com/
the cost of a shaft seal
Jan 15, 2011 | A.O. Smith SQ1102 Pool Pump Motor
Installed new impeller, seal, o ring and square o ring in Jacuzzi Magnum 2 hp. After putting it all back together it leaks alot from around the housing. The o ring is new, and I have tightened as tight as...
the o ring usually would not fit if it were the wrong size. What seals is a ceramic seal, did you change that? If run without water, the ceramic seal will be damaged....
Nov 15, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
1 h.p. pool motor is getting louder and leaks a little. it is about 8 years old. Please, how do i fix it. thanks
The leak is coming from the motor shaft seal.
The loud noise is that water breaching the seal and rusting the bearings.
I can tell you how to switch the seal, but the bearings are much more complicated and I dont think I can thuroughly explain in this message.
Here is a link to manufacturer directions on changing a shaft seal
Please refer to page 10-11 and read on about "pump disassembley/removing old seal"
Then refer to next section for replacing the seal.
There are many different pumps out there, and this manual may not be for yours, but it explains what to look for and how to do it.
Note: When replacing this seal, make sure to purchase the seal plate o-ring, as well as the diffuser o-ring other wise it might not go back together correctly.
If you have the model of this pump, and you want me to help get you part numbers, just reply to me here or reach me @ adamh@newconceptchem.com
Please vote positively if this has helped
Oct 31, 2010 | AO Smith 1/2hp Pool Pump Motor Ao Smith...
MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V: I'm a new pool user and can't get the pump to prim...
WELL LET ME SAVE YOU FROM THAT JACCUZI .. GET RID OF IT, GET A STA-RITE DURA GLASS.. PARTS ARE HARD TO FIND FOR JACCUZI.. BUT IF YOU LIKE PAIN, YOU MIGHT GET THE LID O-RING AND THE SHAFT SEAL FROM YOUR LOCAL POOL STORE. ASK HOW TO REPLACE THE SEAL AND DO IT RIGHT.. PRIME PUMP AFTER A REPAIR! VOTE IF I WAS HELP ...J
May 17, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have water leaking from the bottom of the ring lock.Took it apart don't see rubber o-ring.Is a rubber o-ring normally installed around the outside of the impellar housing?If so do you know the part...
You should just have a "O" ring on the difuser about a 2" ring at the center opening and one about the size you describe on the seal plate or in the pump housing. Ether one at the outer edge. You probally have a bad seal. You will need to remove the impeller and replace this before you put the pump back together. Generally if you pull the wires and take the pump to the poll store they will do this for you for the price of parts and can match your "O" ring's to the pump at the same time. This is always your best bet once you open the pump to get all this done at the same time. Good luck.
Mar 06, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
HAYWARE POOP PUMP
The pump should not shut itself off unless you have one of the newer 2 speed 2 phase pumps witch has its own proming mode. However a reason for loosing prime can be a simple pump lid O ring. It can also be the valves on the intake side of the pump. Try getting the pump going and the switch it off look and listen for leaks or air leaks you can either replace the needed O ring or apply 100% silicone to the leaking area with the pump on and that will seal the leak. Leave the pump running for 8 hours if using silicone. First start off by lubing the pump lid O ring you can use Vaseline.
Jun 25, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Air in pool
you need to look at all intake pipes and seal ('O' ring) around pump skimmer box.
Use a bucket of water to tip over pipe work (while pumping) see if you can see where leak is.
Go to your pool shop and get some multipurpose pool lubricant used on o-rings and gaskets - put on all seals.
http://www.poolcenter.com/service_repair_supplies_sealants_lubricants.htm
May 21, 2009 | Pentair Challenger High Flow Pool Pump 2...
Hayward SP3210 15 TriStar Max Rate Pump 15Horse Power Logo
111 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
