Question about Poulan Garden
Bar oil leaks when not running. Why? - Poulan Garden
  • 2,019 Answers
Why worry about it? It is much more important that it oils than that is leaks.
Just empty it when not in use.
Bar oil is free if like most people, you just use old engine oil.
The chain may have rubbed and enlarged the opening, but if it does not drain too fast, more oil is much better than too little.
There usually is no mechanism involves, just a small hole.
Posted on Dec 29, 2010
Why does my john deere chain saw leak a lot of bar oil after i get done running it?
There bar oil seal is not that great it wears out right away and leaks instead of squirting oil when you pump it.
Don't worry 80 % of all chain saw leak sooner or later. Just put oil when you use it then drain it when you store it.
Oct 19, 2014 | Garden
Bar and chain oil leaks when not running
This is normal as the pump creates a pressure vacuum to pull the oil through it to the bar. If you are concerned about this, open and then close the oiler cap. This will relieve the pressure much like in a caulking gun or gen. purpose pump sprayer. Hope this helped.
Nov 22, 2013 | Echo CS600P Gas Chainsaw 20 Inch
My stihl ms390 chainsaw leaks bar oil, so i put a threaded plug in the hole, and when i get the plug far enough in, it impedes the oil flow to the bar.
Take the bar off and clean all the pieces and parts where the bar mates to the motor. Make sure the hole on the side of the bar, where the oil gets onto the chain drivers, is not plugged. Make sure there are no burrs, on the edge of the bar from chain wear, which will push the bar away from the chainsaw body leaving a gap for oil to leak. If your bar is worn, most bars can be flipped over and used either way. If it is made to be used in on either side it will have a hole for the oil to get into the bar on both sides. Alternating or flipping the bar will make it last a lot longer.
Something else to check is if your saw has a breather hole and if that is what is leaking or it is plugged and is not allowing the tank to breath. Not all saws have this feature.
When you store your saw it is best not to store it on its side with the bar hanging down as these position will cause more oil to leak.
Even if you have a perfect fit/seal, between saw and bar, oil will still leak if it is stored in a place with temperature fluctuations. This happens from the oil expands, when it warms up, creating pressure in the tank causing oil to leak out. I always put a piece of cloth on top of a plastic base to prevent seepage onto any surface. I run chainsaws professionally for over 35 years and they all will leak when stored in place with temperature changes. Some are worst than others. Hope this helped.
Sep 29, 2013 | Stihl Garden
Chain saw setting not running the bar oil leaks out, but doesn't if laying on its side
what kind of saw? where is it coming from? all saws will leak some bar oil so how bad is the leak?
Sep 22, 2013 | Husqvarna Garden
Leaks chain oil out while setting, not running
The oil inside the tank will expand and contract with heat and cold from where it is stored. It is good to check and see that there is nothing between the bar and the body of the saw which causes the two parts from having a good seal and leaking oil instead of having all the oil go into the bar channel. Take the side cover and bar off the chainsaw and clean where all these parts meet. Sometimes it will not leak as much. If you store a saw in a place that has temperature fluctuations some oil is always going to leak out. I've always stored mine in a plastic container with rags on the bottom.
Sep 22, 2013 | Husqvarna Chain Saw 20" Bar
Chain oil leaks out quickly a rancher 55
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Jul 11, 2010 | Husqvarna Chain Saw 20" Bar
Bar oil leaking after use
Release the chain brake, back off the chain adjustment screw several turns, then remove the side cover and the bar/chain. Clean the engine side case where the bar fits to and run the engine for a few moments--oil should ooze out of the side port in the engine. If ok, then clean the removed parts including the two small channels in the drive end of the bar that convey oil out to the chain groove on each side. Reassemble everything and then run the tip of the bar near some cardboard for several moments at speed--it should throw off a thin line of oil onto the board. Unless you have a leaking oil line or the tank is split, you should have minimal leaking problems. Hope this helps!
Jun 27, 2010 | Poulan 1630 16" Chain Saw
The 330 homelite chain saw bar is not getting oil.
If the pump is a piston type, there must be valves on both sides of the pump to control the flow of oil in one direction. The one in the tank is called is called a 'duck-bill' valve and may be mal-functioning. Can you move the diaphragm by hand to see if it pumps anything? Did you run the engine without the bar and chain attached to make sure the bar oil-ports were not choked up. Oil should ooze out of the engine side port when running. Hope some of this helps!
Apr 10, 2010 | Garden
Leaks bar oil
The chainsaw squirts oil into the oil hole in the bar. The chain picks up the oil and carries it all the way around the bar lubing it and the chain. When you quit running the saw there is still a lot of oil on the chain and all away around the chain guide in the bar. Once you quit running it and it sets a while all the oil will follow gravity and run to the bottom of the bar and drip out into the case. It's just another one of life's little nuisances. Have a nice day! Obwhon
Oct 01, 2009 | Poulan 1630 16" Chain Saw
Garden Logo
93 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
