Question about LG DLG2525S Electric Dryer
How do you remove the knockout from the bottom of an lg dryer so you can vent out the bottom
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Want to vent dryer from bottom. How do I remove the bottom/side
Unplug the dryer.
Open the dryer door.
Get on your knees and look up.
You will see 2 phillips head screws that must be removed from inside the door cavity.
Remove these screws, then the top of the dryer.
Then remove 2 screws on the right and left inside of the dryer.
Unhook the door wires and remove the front panel.
Posted on Feb 21, 2009
  • 36 Answers
SOURCE: dtyer load and air not venting to outside vent
The blower motors on these dryers can be packed with lint. It is a fire hazard. The entire front of the dryer has to be removed.
Posted on Jul 04, 2010
How to change output vent from side to bottom on my Fisher paykel de05-us2 dryer
It should be able to be accomplished by using an adjustable 90 degree elbow you can buy at a local HomeDepot or Lowes. The elbow should be 4" four piece adjustable ell. The radius of the ell should match perfectly with the knockout on the bottom when slipped over the discharge opening of the dryer.
Mar 04, 2015 | Fisher and Paykel Dryers
I have a Whirlpool Calypso gas dryer, vented in the back. Can the venting be changed to vent out the side?
some dryers have a round "knockout" on either side which would allow for different venting options. You also need to check the ducting inside the machine to determine if it can be re routed without causing a sharp bend or kink that would cause over heating and lower efficiency.
Apr 30, 2011 | Whirlpool Dryers
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
How do you change the air flow from the back to the side? maytag preforma
inspect the dryer sides,and see if there is a knockout to remov to allow side venting,some dryers are not side ventable,if the knockouts are there, you may need a kit from maytag specifically for that model...the installation instructions may be helpful if you have them,could provide kit no.,and the how to instruct.
Mar 06, 2010 | Dryers
We are moving the dryer and need to open the side vent and plug the back vent. how do we do this?
Unplug the cord of the dryer before starting.
Raise top by placing a putty knife between top and front in the seam between the two about 2 inches in from each edge and lifting up at the same time. Raise top to full open position.
Look down inside the open top dryer at each side there will be a screw on each side a few inches down. Leaning against the front remove the two screw and pull the top forward a few inches and raise it from the supports at bottom then swing it aside protecting any wiring.
This will give you access to the underside of the dryer at which point you can remove the vent tube going out the back. Remove the side knockout by hitting the edges of the cutout with a screwdriver until it breaks free. Run a new line from the fan outlet through the new penetration. This tube can be rigid or flexible but must be non-flammable material.
The rear hole does not need to be plugged unless you have pets, mice or children that might get inside. It can be closed with aluminum tape if desired. Give your dryer a thorough cleaning with a vacuum while apart.
Reverse the disassembly process to reassemble the front and top being careful not to disconnect any wiring.
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
Need to move the dryer vent on LG DLE5955 to the side opening.
you shouldnt have to buy anything. remove the access panel in tne rear. remove the knockout from the side panel and relocate the exhisting hdwre.
May 03, 2009 | LG DLE5977 Electric Dryer
Change dryer vent from side to rear
Not all dryers have the facility to vent out of the side, if they can , you should see a knockout panel or cover at the side, remove this and fit vent to side.
It is important that you blank off the outlet where the hose was fitted originally.
Plz rate my answer.
Thanks..
Jan 20, 2009 | Dryers
41780042990 Kemore electric dryer
you would need to "punch out the metal" , youl also need to remove the fron tof the unit(2 screws approx 3-4 inches down form inner panel, holding front panel on, ( youll need to remove the top of the dryer( a few screws across the back of unit.) andthen disconnect the dryer belt(easiest acess through a small acess panel on lower rear of unit, pull the dryer drum out and youl see the existing ve, just a matter of attaching a 90degree elbow and running vent out the side instead of out the back. DISCONNECT POWER TO UNIT FIRST!!!!!!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
How to open lg dle2514 front load to clean blower and vent
Remove the 3 screws holding the top of the dryer.  Push the top towards the rear and remove top.
Remove the front control display board by removing the 2 screws and unsnapping the control panel.
Remove the 4 top screws hold the front panel and the 2 bottom screws in the door frame area.  Remove the light switch wire connector.  Tilt the front panel forward and lift up.
Apr 29, 2008 | LG DLE2514 Electric Dryer
LG DLG2525S Electric Dryer Logo
159 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
