Question about Mtd 22" Yard Machine Push Mower
Mower starts and runs,but when it gets hot it stalls?
Why does my craftsman riding mower choke itself off when too hot
Clean the carberater the carberater is the number one problem for craftmen lawnmowers pay close attention to where the springs are hooked there are several holes the spring can go in take it apart slow and clean every littel hole and put it back together take your time dont get in a hurry its not to hard just time consuming then anythaing sholdent take a newbie more than 2 or 3 hours max me half an houre
Aug 18, 2014 | Craftsman Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
My 26 hp craftsman tractor stalls and won't start when it gets hot
being that would be a twin cylinder engine and has two sep coils does it missfire before it dies?does it have spark when it dies?does it sputter then die like it runs out of gas where the cap vent could be plugged and it vapor locks if you spark carb cleaner or starting fluid the solenoid on the bottom of the carb shutting off that should give you something to start with
May 01, 2012 | Craftsman Garden
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Stalling after one hour run time
Sounds to me like you need to replace the ignition coil,they will go open when they get hot and when this happens the plugs will stop fireing.
Apr 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Sep 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
22hp intek eng stalls when hot starts and runs fine until it gets hot.
you have an overheating problem with your motor then. take it to the shop and have them check it.
Jun 30, 2009 | Craftsman Garden
Mtd 22" Yard Machine Push Mower Logo
166 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
