Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
My vaportizer spits water and sounds like it is boiling over. I've tried experimenting with the salt by adding just a little to adding a lot. This doesn't seem to make a difference. Why is it doing this?
2 Suggested Answers
  • 1015 Answers
SOURCE: I bought our Vicks vaporizer and it worked great
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Posted on Dec 16, 2010
My humidifier is spitting water plus steam. Kind of weird. Didnt do before. Level of water is ok, added 1 flat tablespoon of sea salt and 2 tabkespoons of vick oil. What's happening?
More than likely, mineral scale has built up inside the tank and the mist tubing.
To clean it, turn the unit OFF & unplug it. Empty any remaining solution that's in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Plug the unit in and turn it ON. Allow it to run for 5 minutes, then turn unit OFF and allow it to soak for 30 minutes to and hour.
Then turn the unit back ON. If the water spitting has stopped, run the unit unit is half empty. Turn it OFF, unplug it and empty any of the remaining solution. Refill with Bottled Distilled Water and run it until it's empty. Doing so, will flush out any of the remaining solution and scale.
In the future, it is best to use Bottled Distilled Water, rather than tap water. As the Distilled Water does not contain any harmful minerals or chemicals.
Hope this helped you and thanks for choosing FixYa.
Sep 15, 2011 | Vicks V150SG 1 Gallon Humidifier
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vicks vaporizer is not blowing steam is it suppose to. rfinson30@yahoo.com
This vaporizer has two carbon electrodes covered by a 3in black cylinder with a couple of recessed phillips screws that take a narrow long shaft phillips screwdriver. Those two carbon electrodes are about 3/4 inches apart, and the water + a sprinkle of salt set up a resistive path between the electrodes that produces a boiling action on the water, thus steam.The electrolytes in the water, (calcium, iron, magnesium) eventually create a bridge between the electrodes, that allows the voltage to cross the electrodes without heating the water. You would have to take the cylinder off and scrape the built up electrolytes off of the carbon electrodes and reassemble the device, but you can buy another for about 15 bucks, but the same thing will happen again. If you try to use a little less or no salt on the next one it will last a lot longer.
Feb 03, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer is spitting water
You added too much salt. Clean it out, start over with less salt.
Feb 08, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Spitting noises and gushing water
Another alternative to vinegar is to use lemon juice. About 1 cup to a tank of water should do the trick. It smells much better than vinegar and also has the acid content to clean the vaporizer.
Jan 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
The humidifier spits hot water out and sounds like
Try soaking the heating unit in lime away or vinegar to remove lime deposits, if that doesn't help add a small amount of salt to the water.
Oct 31, 2009 | Vicks V150 Humidifier
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
163 people viewed this question
Top Vicks Humidifiers Experts
paulcarew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
