Question about Refrigerators
Whirlpool ice door flap pivot pin tab broken
I read in a previous thread that you had a kit that would repair this without having to replace the ENTIRE DOOR. I tried to look you up on Ebay without any success. Is there anything still available?
  • hhummel43 Aug 12, 2008
    Kenmore 106.54536400 same as Whirlpool side by side pin retainer is broken off of ice
    maker dispenser housing. It holds the door flapper for the ice
    dispensor. The repair guy says that I have to replace the WHOLE FREEZER DOOR, because of this tiny little plastic pin retainer.
I have a Whirlpool side by side, model GC3SHEXNT03 that had the plastic hook that holds the ice door pivot pin. While we can question why they make it out of plastic given the number of posts I've seen with people having the same fear that I had....Replacing the whole darn door to fix 1 little piece of molded plastic. I found some posts about an Ice Door Repair kit, but wasn't sure if it would fix my issue. Luckily I live about 8 miles from the RepairClinic.com warehouse in Michigan, so I went to talk to them to see. Nothing in the discussion was definative, but the have a 30 day return policy so I bought the kit for $74 (ouch!) and it worked beautifully. I have an ice dispenser once again. I know what some of you may be thinking...I work for them....Nope, I'm a computer techie that HATES paying repairmen!! And I'm posting this in the hopes of saving someone the 2 weeks of Googleing that I did trying to find a solution, short of replacing the door. Here is the link to the kit, I hope it helps somebody out there.... http://www.repairclinic.com/Appliance-Parts?s=t-8201756-%3d%3d should be Item #1164531
Posted on Feb 13, 2009
The Whirlpool Ice Door Kit 8201756 kit works. It may not look like it, but the big metal bracket fits neatly into the top of the cavity, and works to hold a new door flapper (provided).
It attaches using a bunch of heavy-duty double-stick tape mounted on the top and on the back, and by attaching a small support bracket to an existing screw.
The only hard part is removing the front plate (#21). It's held onto the dispenser body (#1) by four tabs on the panel itself, two at the very top and two at the very bottom. Push the bottom edge of the panel down and then pull it out FIRST so you don't break the top tabs. It takes a bit of force. Don't use a screwdriver to pry, or you'll damage the plastic.
Once the bottom is loose slide the plate up and off, then disconnect the six-pin molex connector. Unsnap the interior plastic bracket (#15) and pivot it up and out of the way. Use a piece of duct tape to hold it to the door.
Remove the old flap assembly. You'll then have to remove what's left of the the two plastic "hook" tabs. This can be done simply breaking them off with a pair of pliers, or, as I did, using a Dremel cutting blade to slice them off.
Keep the solid tab without the holes in it. You'll still need it to "stop" the new pin from sliding out.
Practice getting the new metal bracket in place a few times before you peel and expose the adhesive tape. Be careful with it. It's very sticky, and will setup quickly.
Attach the support bracket using the big screw on the front of the water dispenser. Attach the new ground wire by unscrewing the existing green wire from the door and reattaching it. When done you'll have two wires there.
You may find that the delay mechanism (#8, the black piston thingy) still manages to pull the flap pin up and out of its new metal slot. I removed my display mechanism completely, and have no problems. In fact, I prefer the door to close immediately.
Hope this helps.
Posted on Aug 03, 2011
I had the same problem. I used JB weld epoxy, I placed pin and spring in place I held with a small
peice of wood then applied the epoxy. I put the epoxy in 3 layers about 15 min apart. Its still holding,
and saved me $650.00 for a new door. Hope this works for you.
Posted on Sep 17, 2008
There are parts for fixing freezer flaps on sale at http://www.koalabits.co.uk I used them to fix my own door and has worked well
Posted on Jul 11, 2009
The pin was taken out of our ice dispenser, now the freezer is icing up by the shoot. How do i get it back on?
Posted on Jun 27, 2009
Ice dispenser is jamming up
hi there.this is difficult without a visual but u can check a few things. 1-is it jamming due to ice chunks build up or not.2- ice chunks forming on the whole bucket or just near the exit flap.3- if the whole bucket then check inlet valve and water pressure.4-if near exit flap then the flap is not shuting properly due to weak return spring/seal /flap pivot./links or flap valve.hope this helps good luck.Ali
Aug 23, 2012 | Whirlpool GI5FSAXVY Stainless Steel ...
Housing tab that holds metal pin on my Whirlpool refrigerator ice chute is broken, what can be done about that?
Model #KSRP22FNSS00show?id=y6f3ez5blva&bids=92089.720769097&type=10&subid=, this side by side refrigerator, according to the customer was having major problems as a result of the ice door mount breaking preventing the door from sealing when shut. The customer also described the freezer looking like a winter wonderland from all the frost built up on all the food. Another servicer visited this customer and told them the only way to make this repair was to replace the entire door which has a cost in excess of $500 and by the way, it's on back order. Not happy with that answer, the customer called me to see if I had a better solution to get this 2 year old refrigerator working properly again.
Now I want to start by saying I normally will support others in my industry as we are all capable of mistakes and as long as we are trying our best to take care of the customer, I am cool with that. But I get quite frustrated with what I consider fly by night servicers that are willing to take the money, but do little to help the customer. My advice is do some research and don't just let anybody into your home to service the appliances you worked hard to pay for. Enough said.
By the time I arrived, the customer had moved the refrigerator into the garage as it was simply unusable in the condition it was in. Because of this, I was unable to see the symptom that started the need for service, but I have seen this happen a few times, so I had a good idea of what she was describing. The problem that the previous tech discovered was the ice door would not close which is a refrigerator part that opens to dispense ice, and closes to keep the cold air inside. This is not a real common problem, but as I said, I have seen a few. What happens is the tab (usually on the right side) that holds the shaft which is the pivot point for the door seal breaks. Once loose, the shaft will often slide out from the other tab allowing the door to fall into the ice chute. Without the door in place to keep air out, well the winter wonderland is usually the result. Because these tabs are part of the dispenser rear panel, they cannot be replaced leaving us with a dilemma of how to fix it. Years ago, the only solution was to get creative with some hardware, or simply replace the entire door for the customer. Not many takers when you consider the part cost, but fortunately, Whirlpool did come out with a rather unique kit to solve this problem and help prevent it from happening again in the future.
Jul 27, 2012 | Whirlpool Refrigerators
Flap on Ice chute came off I need to put it back on. Whirlpool Refrig. With water and Ice with a flap over the ice to keep hot air from getting in.
I'm in the middle of the same problem on my own refrigerator right now. The flapper swings on a steel pin which passes through a stationary plastic tab. That plastic tab can break off, allowing the door to fall out of position. Look up into the mechanism to see if this is your problem. Whirlpool makes a modification kit, part #8201756. It's not on the original parts list, so do a web search for Whirlpool 8201756. I hope this helps.
Jul 10, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a whirpool side by side refridgerator and the door flap to the ice dispenser isn't closing.
Look up into the door area from the outside with a flashlight there is a good chance that a plastic tab that holds a metal hinge pin is broken. If so you need a kit to repair this problem.
Apr 15, 2011 | Whirlpool ED2FHEXM Side by Side...
The flap on the ice despenser is not closing and water is forming in the pan below. Is there an scamatic of the door ice maker despenser?
If you can look up and see the flap is loose or sloppy, you need one of these two kits. Kit # 8201649 is the chute door, door bracket, spring, damper pot.
Kit # 8201756 contains all the above plus a metal bracket designed to replace the housing bracket, the door pivot pin and a metal brace.
May 10, 2009 | Whirlpool ED2FHEXM Side by Side...
Ice Chute door dislodged
IF THE ICE DOOR HAS COME OFF, THE CHANCES ARE THAT THE PLASTIC TAB THAT HOLDS THE HINGE PIN IN PLACE HAS BROKEN. IT IS PART OF THE PLASTIC HOUSING. WHIRLPOOL/KITCHENAID HAS A FIX KIT THAT REPLACES THE PLASTIC TABS WITH A METAL BRACE THAT IS PRESSURE TAPED IN PLACE. I HAVE INSTALLED A COUPLE OF THESE KITS AND IT TAKES PATIENCE AND TIME. THE KIT WILL HAVE INSTRUCTIONS ON HOW TO INSTALL. FIRST VERIFY THAT THE TAB HAS BROKEN. IT IS LOCATED IN THE UPPER LEFT SIDE OF THE OPENING TO THE ICE CHUTE.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool pin retainer is broken on ice dispenser
this is easy. there is a small area beside where the piece broke off. bend a small peice of metal coat hanger at a 90 degree angle, (this is so you can make your new hole on the correct line) heat the end with a lighter, burn a smallhole thru this area beside where the previous hole existed. now throw away the old pin that you were using and use a piece of coat hanger cut to the right length. on one end bend about one half inch to 90 degree angle, feed thru new hole and thru your spring and flap and thru to opposite side hole and lastly make small bend to keep wire from sliding out. ta da, fixed. problem solved for about two cents. i have successfully repaired many of these doors.
Oct 09, 2007 | Whirlpool ED2FHEXN Side by Side...
Pin retainer broken off from ice dispenser housing
Ill be gald to help you here....The people who answer the phones must be worthless, anyway the part number is 8201756 (ice door kit) it will probably have to be specially ordered, i have installed several and there not exactly easy but it can be done with some patience. Pass this along to your repair guy as he is not giving people correct advice.
Refrigerators Logo
2,996 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
