Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
TV won't turn on
After plugging the TV into an outlet I know to be hot (working), and pressing the power button (either on TV or on the remote), I hear a "click" indicating power is flowing into the TV, but the TV doesn't turn on.
Instead, all I get is a blinking standby/timer light that flashes 5 times, stops, flashes 5 times, etc. etc.
Tried resetting by holding reset button on remote down and pushing power button on TV; no effect. Tried unplugging for 12 hrs; no effect.
Sony repair says light blinking 5 times indicates the general nature of the problem.
TV had been working fine until power went out during strong thunderstorm.
Thank you for your help
  • 1 more comment
  • kstewart Jul 07, 2008
    Dan,
    Yes, capable of self repair, just need to know what and how. No indication of problem prior to storm.
    Thanks Dan
  • tvdunbroke Jul 10, 2008
    i have the exact same problem. today something happened to trip the main breaker on my house cutting the power off. I through the breaker and continued watching TV. When I returned from dinner I could noy get thr TV to turn on. 5 blinks. Has anyone found a solution for this.
  • Anonymous May 18, 2009
    My remote ctrol won't work.. I've even changed the batteries twice!!! WHat else can I do to get my TV to work?
  • 4,234 Answers
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Posted on Jul 07, 2008
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
ELCHW402 won't turn on
An internal relay may have failed.
Dec 08, 2017 | Element ELCHW402 40 in. LCD HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I bought LCD TV 32"
Check to make sure that the power cord is plugged in. If it is, plug something else into that outlet to test and make sure that the outlet works (use a lamp or something that you know works). If the outlet doesn't work, check your breaker box for a popped breaker. If the outlet works, and you are sure the power cable is connected properly, then you need to return the TV to the store where you bought it. Most retailers have at least a 30 day return policy for defective merchandise.
Apr 03, 2011 | Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
Philips Projection tv will not turn on
Not trying to offend you here at all, but ....
1. Plug something else into the same outlet and verify that the outlet works.
2. Look at the power cord for any damage like wear and tear near either end of the cord.
3. Once its plugged in see if you can turn it on using the power button on the front panel (not the remote)
4. If it came on using the power button then there is not a problem with the TV.
5. If it did not come on then Sorry I can't help.
6. If it did come on then make sure the "tv" button near the top of the remote (assuming its the original remote) was pressed before pressing the power button on the remote.
Jun 01, 2009 | Philips 55PW9363 55" Rear Projection...
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
447 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
