Question about HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
On the back of this power supply, Theres a red switch with the numbers, 115 and 230. depending on which way it was switched on. Can someone please explain to me what this is?
    Sergeant:
  • 320 Answers
Hi inforis,
That is a setting that will change the voltages, and you do not want to flip that switch. If you do there is a chance you will fry your computer. Different countries use different voltages. It's cheaper to make a switch & some circuits inside the PSU than make a whole new one. List of countries with frequency & voltage (http://www2u.biglobe.ne.jp/~INTECS/WorldVoltage.htm)
Hope that answers you question well enough.
Posted on Dec 29, 2010
How to resolve PoE fault hp5400zl
Those switches have a lifetime replacement warranty. Find the number you need on this website: http://www8.hp.com/us/en/contact-hp/phone-assist.html
and have the serial number of the switch handy. have the switch plugged in and running and have a laptop and a console cable ready before you get HP on the phone. If it comes down to being a problem with a part they will either send you the part you need OR the whole switch depending on what the problem is with the switch. Most PoE faults are power supply problems. if your switch has more than one power supply be sure the connect both of them to power as HP POE switches that have more than one power supply, 1 power supply gives power to a certain portion of ports and the other power supply will give power to another portion of the ports. Much good luck!
May 21, 2014 | HP 24-port 10/100/1000 Poe Module For 5400...
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
My f250 2002 my stop,turn and 12 volt supply aren't working, fuses are all good, someone said theres a relay un der the hood that controls the trailer plug directionals, is thair any truth to that
Yes. Sign up on the Autozone.com site for free and you can get Powerbox layouts and wiring details. Also check your Relay number on the part. Ford often usues the same Relay for the horn and they can be switched to test the relay.
The turn stalk can also be a problem. All turn lights run to it. Sometimes if you have the Hazard on the column, just pressing the Hazard button will reset the points for the turns. They use a derailer system and sometimes the points do not return back to center.
I hope my solution is helpful.
Jun 23, 2012 | 2002 Ford F250 Super Duty SuperCab
My 37LG10 TV has the red light on like its getting power. Then when I try to turn it on it flashes green then goes right back to red. I opened it up to see if any fuses or capacitors blew but all the...
Most probably Flyback need replacment, all power source comes from flyback after switching power supply is turned on (in your case power supply works since your LED comes on)
Take to repair shop
Aug 22, 2011 | Televison & Video
Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 26, 2009 | Akai LCT2701TD Television
My tower will not turn on I don't know what could be wrong with it under the power supply it's red. I only had it for a few month's and I tried everything.
does the power supply come on? theres a little switch on the back of the power supply it says 110 or 220. make sure its on 110. Also the red is coming from a light on the power supply or on the boards below the powersupply?
Apr 15, 2009 | Computers & Internet
It doesnt turn on.
Hi there, I would try replacing your power supply all together and see if this helps.
Mar 18, 2009 | Acer Aspire™ T180 PC Desktop
Red standby light blinks
Check you power supply. May want to replace it. Part number BN44-00100A. Average cost $60
Best regards
CircuitCity
Dec 01, 2007 | Samsung LTN1535 15 in. HD-Ready LCD...
Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Mar 21, 2007 | Pioneer PureVision PDP-5030HD 50 in....
HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply Logo
67 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
