Question about Xerox Phaser 8560MFP Laser Printer
Ink stick is jammed way down in the chute - Xerox Phaser 8560MFP Laser Printer
  • reorante Apr 21, 2009
    I have the same problem, but I´m not sure if every phaser 8560 has a translucent plastic piece over the ink sticks that won´t let me use the screw, is there a way to take that piece out and do it bare hands?
    President:
  • 2,072 Answers
What I normally do it is take about a 2 or 3 inch wood, dry wall type screw and twist it down into the ink stick and work it back up out of the ink loader.
It's about the easiest way I have found to remove blocks, if the block fragments use some forceps or think needle nose pliers to remove the remaining pieces.
Posted on Jul 07, 2008
My Xerox 8550 says 'ink sticks are jammed'. Yet,
This could be a print head problem. If the print head is calling for ink and the sensor is bad the ink melter will continue to melt ink and over flow the print head. In which case the print head need to be replaced.
Also it could be a problem with the ink melter. If it isn't melting the ink it will cause this error.
To get to the ones at the end of the chute I stick a long screwdriver and break it free from the melter.
Harry
Jun 04, 2010 | Xerox Phaser 8560MFP Laser Printer
Error code 09038.46:72241
That code is a back stick count failure.
You want to look in your ink loader, see if there is a stick jammed, twisted, broken or in anyother way out of place or hung up in the slot.
Be sure you loaded a 8550 stick also, since the shapes on the different phaser printer sticks are all different.
You may have to carefully remove the black sticks and reload them. You can take a screw and screw it into the ink stick, slide it back and remove.
Most likely you will find a gap in the ink sticks causing the problem. Here are the Xerox support page instructions.
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes. If non 8500/8550 ink sticks, whether manufactured by Xerox or by a non-Xerox ink vendor, caused the ink sick jam, contact support to place a service call.
Mar 09, 2010 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560dn says it is out of Cyan ink, but it is not.
The inksticks are probably jammed in the slot. If you're using non-Xerox ink, an error reset is required. Since the non-Xerox ink sticks are not the right shape (since the shape is a registered trademark), they don't always trip the sensors when they come down the chute.
Jun 05, 2009 | Xerox Phaser 8560DN Laser Printer
Ink stick is jammed way down in the chute Is there no way to open this $$!&$%!, because the ink turn around when moving it and now that jammed, that I would have to use to much force, which would...
What I normally do is take a screw, a dry wall screw is what I use. Thread it into the ink block and that makes it easier to work it back up and out of the ink loader.
Those are tough, I agree. If you have to break the block, you can get a crevice took into it and vacuum it out,, CAREFULLY !!!!
May 27, 2009 | Xerox Phaser 8560MFP Laser Printer
Error 09,036.44:41689
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
May 01, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not
appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the error.
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
Phaser 860. I replaced maintance kit and it came up with sevice a
--> The yellow ink sticks are jammed.
Open the ink loader and ensure that the yellow ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks. And use the link below for any other problems you may have.
Niallbt
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=117,E=0000000000024637030,K=5840,Sxi=17,command=restart,ques=user_type:4,ts=xo_legacy,varset=prod:860
Mar 08, 2009 | Xerox Phaser 8500/DN Printer
Error messge xerox Pahser 8200 09.007.42:11683
Dec 07, 2008 | Xerox Phaser 8200 Laser Printer
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Error Code 09,038.46:103468 help!
Mar 20, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
605 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
