Question about Macally IceCam Personal Web Camera
The Video feed looks Yellow and has a fog on it I cannot wipe off
    Genius:
  • 1,325 Answers
Hi
i have this webcam too -- it works well with skype, yahoo -- not too many applications work well with it.
you can go to this link for further help and driver download.
http://www.macally.com/en/product/articleshow.asp?articleid=119
http://www.macally.com/en/Techsupport/Drivers.asp
for manual, go to this link, look at far right
http://www.macally.com/en/Techsupport/Manuals.asp
hope this helps you
Posted on Dec 29, 2010
I was driving and a green light came on that looks like my bright lite what can it be
Your car may be equipped with driving, or fog lights. The dashboard symbols are often similar, with high beams being blue and fog lights green or yellow depending on make of the car.
Dec 27, 2015 | 1998 Saturn SW
Window fogging up
temporary solution is to goto walmart automotive section and look for rainX anti fog wipes. and if you change you control knob to a different zone do you get heat and does it go from vent to floor
Oct 02, 2013 | Ford Expedition Cars & Trucks
How to set up a sony suround sound to a tv!!!! without the manual
it depends on the model #, and where your tv gets its feed source.( dish network, comcast, ant, vcr, dvd player, etc)I have a sony surround with no manual and set it up my self. look on the back where the components hookup to if there is a yellow, white, and red on the input, that is where your feed should hookup to, and there should be a monitor out to your tv,( a yellow video plug ). if your surround does not have a yellow on the input it will bypass the surround and go to tv video in
Sep 22, 2010 | Audio Players & Recorders
Smelling coolant inside the car. windshield fogs up. no leak inside car but does leak outside off of frame on front passenger side. just replaced thermostat but cannot find a leak on any lines anywhere....
Hello razzamatazz2: My name is Roger and I will help with your problem. You are smelling a sweet smell and the windows fog over. The fog is slick and hard to wipe off and smears easily. You have a heater core leak. The only way to fix the problem is to replace the heater core. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Sep 09, 2010 | Pontiac Sunfire Cars & Trucks
I am installing a new after market DVD player. The old device had only 2 wires connected to a plug. The new player has 3 wires. a. Ground b. Power (on and off when key is on) c. Yellow battery (this...
you will need to reset all info each time you power off the unit if you dont connect thas feed, and in some units will not work fully, your car should have a switched power feed from the ignition switch and an aux ( permenant feed ) if not that u can just run it from any permenant feed inc the battery
Dec 24, 2009 | Car Audio & Video
Wiring for Bosch Hologen Fog Lights? Wiring harness has 5 wires from relay, Red to battery, 2 Black - 1 to each light?, 1 Yellow to?, 1 Blue to?, & where do the xtra Black and Green wires go to? These...
Look on the relay for the terminal numbers.
Terminal 30 goes to the battery positive.Red Wire
The two terminal 87 go to the fog lights.Black Wires
Match the color wire with what you have on the relay connection for the rest of the wires.
Terminal 86 should connect to your low beam headlight.
Terminal 85 should go to the fog light switch.
The fog light switch should connect to the terminal 85 and the other terminal on the switch will connect to ground.
Dec 21, 2009 | 1987 Nissan Pickup
How to factory wire fog lights on a 2000 ford f150. pig tail, relay, and fuse are there. Only no wiring from fuse box.
This is a common problem on 97-00 MY trucks, regardless of the trim level ( XL, XLT, Lariat ).
If you install the fog lamp fuse in the BJB ( aka Battery Junction Box, Engine Compartment fuse panel ) Fuse # 9 ( 15 A fuse ) and jumper the normally open contacts in the fog lamp relay socket ( see diagram below ) the fog lamps should illuminate ( to confirm what you have doing on ).
The problem usually is the main headlamp switch to the BJB is not in place ( this is the yellow wire from the main headlamp switch connector to the relay socket pin #1 ).
One easy route is to make an aux lighting relay & harness, or purchase one online. With this, you can cut the factory ends and attach them to the harness you purchased. There is an air inlet next to where the steering wheel column runs through the firewall. This would give you an easy route to the fog lamp switch. The fog lamp switch, you can buy the factory one, and change the yellow wire from the connector to your added relay, or just add a switch for this function.
This will give you an idea of what the DIY relay and harness would look like.
Hope this helps, more than confuses at this point
Sep 16, 2009 | 2000 Ford F150 Flareside SuperCab
'86 Mustang Head Light Switch Pin Out Connectors?
I can give you 94 mustang. Don't have 86 but maybe similar
7fc8945.gif Pin Number Circuit Circuit Function B1 38 (BK/O) Power Supply to Battery B2 195 (T/W) Tail Lamp Switch Feed I 19 (LB/R) Instrument Panel Lamp Feed IGN — Not Used R 14 (BR) Headlamp Switch to Tail Lamp and Side Marker Lamps H 15 (R/Y) Headlamp Dimmer Switch Feed DN — Not Used D1 54 (LG/Y) Interior Lamp Switch Feed D2 706 (GY) Battery Saver Door Switch Feed
Apr 30, 2009 | 1986 Ford Mustang
Replacement of fog lights
drive your lexus to an autozone store and they will take a look at it, sell you the correct bulbs and assist you in replacing them...pretty good service huh!
Mar 14, 2009 | 2001 Lexus IS 300
Poblems with grounding!
i grounded the yellow and blue wire to my fog light ground wire, everytime that happens...i just flip the fog light switch twice and it works again =D
Nov 26, 2007 | Dual XDVD8181 Car Video Player
Macally IceCam Personal Web Camera Logo
1,337 people viewed this question
Top Macally Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
