Question about Dell Inspiron 1545 Notebook
Everytime i type on my raggedy *** inspiron 1545 laptop the pressure pad has me jumping all around the screen. Is mine just screwed up or is it that sensitive.
I had this exact same problem (along with many others) on my 1545. It is because of the awkward position of the touchpad that the ends of the thumbs come across and touch it and move the cursor. This is actually a pretty common thing with other manufacturers too, but it's real bad with the 1545 series. I never did figure out a way to disable it within Windows by itself, I did figure out how to stop it by using third party software. If you download a program called "TouchFreeze" it disables the touchpad whenever you are typing.
Posted on Mar 06, 2011
SOURCE:
How do I turn off the internal mouse pad?
There is no button/ key to turn off Internal Mouse (Touchpad) in a Dell Inspiron 1545 so you may try following the below steps which might help:
    (1)Click start.
    (2)Type device in the search box and select device manager.
    (3)Double click on Mice and other pointing devices.
    (4)Right click on the Internal mouse and select disable.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron 1545 Notebook
My inspiron 1545 types two letters at once
On most laptops there is a function key that will lock the keyboard.
You would need to pres the [Fn] key and the appropriate [F#] key. In mine the combination
would be [Fn+F1] keys. If you shut down to re-activate the keyboard you will loose whatever you are working on.
hope this helps
Aug 15, 2012 | Dell Inspiron 15 1545 Notebook
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
The cursor jumps around when I'm typing -- for example when I'm typing, it will just click itself up a few lines and start typing in the middle of another word
The touch pad can cause this problem. Go to control panel to make it less sensitive. I often drag a finger by accident over the pad and away goes the cursor. It is a major grump of mine also.
This web site shows the details, if you need them, to adjust the touch pad. http://www.ehow.com/how_2292964_adjust-vista-laptop-touchpad-settings.html
I do this for fun, so 4 thumbs if it answers your question.
Sep 25, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
It jumps around the screen when I'm typing
you may be touching the touch pad while resting your thumbs. this laptop does not have a key to disable the touch pad.
Nov 18, 2009 | Dell Inspiron 1521 Laptop
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
My Dell Inspiron 6000 notebook computer curser "jumps around"
I frequently have the same thing when using a Dell laptop. The problem MAY be with the touch pad. Without noticing it, my thumb touches the pad and away goes the cursor!
So try this: Open the control panel and go to mouse. Look at the top for Touchpad. There is a setting in there for sensitivity. Reduce the setting so that you need to apply more pressure on the touch pad to move the cursor. Test it a few times to make sure it is still functional before closing the control panel. Then try typing something in a word processor and see if it is any better.
Good luck, and please let me know if this helps.
~ Spoem
Mar 30, 2009 | Dell Inspiron 6000 Notebook
Only have half screen on my Dell Inspiron 1501
What your describing is a failure of the LCD or possibly the inverter cable connection to the LCD. Most likely an LCD replacement will be required.
LCDs run around $150 on Ebay
Jan 25, 2009 | Dell Inspiron 1501 Notebook
Laptop
are U sure therees no Handphone or mangentic things near the laptop? did u use usb mouse? optical mouse?
Aug 26, 2008 | Acer Aspire 5315 Notebook
Dell Inspiron 1545 Notebook Logo
238 people viewed this question
Clive
Clive
Alun Cox
