Question about Toys
Stealth flyer ii bottom propellor wont rotate. any help on how to fix
Ya, I've got that problem too. I note that the bottom rotor spins without turning the gear inside the copter (I can hear the gear when I turn the top rotor. So I'm thinking that maybe the rotors plastic sleeve was glued to the shaft and that came loose. But I'm a little hesitant to put glue in there until I'm sure!
Posted on Jan 03, 2011
  • bryan534 Jan 03, 2011
    OK! Got it figured out! Glad I didn't use glue!! So it turns out there are two shafts, one inside the other. What you have to do look for the side of the chopper body that has most of the screws. Use the little screwdriver from the spare parts kit to remove all of them. Make sure you get all of them! Even the ones on the seam at the bottom, and the ones on the tail. (And make sure those little suckers don't roll off the table. I lost one, but there were spares in the spare part kit). Ok, now start at the tail and then the nose and gently, persistently pry the two have of the body apart. Some tiny wires inside, so be careful. Now you see two large plastic gears -- turn them each and you will see the upper and lower rotors turn, The upper gear is for the lower rotor. Now look close just forward of the upper gear and you will see a very small gear, that obviously is supposed to mesh with the upper large gear. But if you have the same problem as me, it has raised up and no longer meshes. So use your fingernail to put just enough pressure straight down to push it back down to mesh. That's it! Now carefully put the two halves of the body back together. Watch out for the tiny wire running to the tail LED -- make sure it rests inside the body and doesn't get caught in the seam. Screw it all back together, and you should be flying again!
    Problem Solver:
  • 15 Answers
Posted on Jan 06, 2011
Great white wont turn motor runs but wont turn
Do you mean you can hear the motor turn but the propellor doesn't turn?
Then check the break-pin of the propellor. It's a security device that will break when the propellor hits an object in the water...
Sep 27, 2016 | MotorGuide Great White Saltwater Series...
When the fan rotates it makes a loud noise. Sounds like it needs oil. Where can I put lubricating oil?
Simply disassemble where its possible and find the place of the bearings most its short right behind the propellor where the shafts come out the motor if it is hard to find for an accessible place spraying wd40 with the hose pipe on the canister behind the propellors can may be help do not use sewing machine oil because of the time being it accelerates faster dirt in the sliding bush of the shafts.
Apr 25, 2016 | Minka Lavery Minka-Aire F502-Bcw,...
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
Jul 01, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth pro wont connect to pc
trio tablet ge wram when chargeing and want power up
Feb 26, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
How do I rotate info when creating flyers for events?
when printing, the print dialog should have a 'portrait' and landscape option. change to landscape
Oct 15, 2013 | Computers & Internet
My train wont go in reverse
Try flipping the "Reverse" switch on the bottom rear of the locomotive.
Jan 03, 2011 | Lionel Pennsylvania Flyer Train Set
Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Toys Logo
1,296 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
