My mouse pad dont work on my Compaq and i have tried enabling it through my control panel
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 123 Answers
Which one model
please click yes for vote
Posted on Dec 29, 2010
Mouse pad stalls and i see a little red light on the mouse pad....i have a compaq laptop but not sure what version...how do i disable thi feature so i dont have to use a physical mouse
The little red light is likely from the red LED underneath your optical mouse. If the mouse cursor/pointer on the screen is jerky, it may mean the mouse pad is dirty and/or if the mouse is wireless, its battery is low and should be replaced. Most laptops have a touchpad as part of the keyboard. If you want to use that instead of a physical mouse, just put the physical mouse away and use the touchpad. Both should be active unless the touchpad was disabled. If the touchpad is disabled, you can re-enable it by clicking on control panel > mouse > device settings tab > enable button.
Mar 16, 2011 | Computers & Internet
I have a compaq 620 and would like to turn OFF the mouse / track pad under the keyboard... please help!
Try these solutions: > 1.. F10 to enter bios setup at boot time
> 2.. Advanced
> 3.. Device Options
> 4.. Dual Pointing Devices
> 5.. Use arrow keys to select the pointing devices you want enabled
> 6.. F10 to save settings
> 7.. File-Save changes and exit
> 8.. F10 to confirm
>If the Synaptic's Touchpad driver is installed
touchpad/point stick can be
>enabled/disabled via the mouse properties in the control
panel applet.
Or:
> 1.. Start
> 2.. Control Panel
> 3.. Mouse
> 4.. Device Settings Tab
> 5.. Select the device and click on the enable or
disable buttons. "
If this helps, please rate. Thank you.
Jan 18, 2011 | Compaq Evo N610C Notebook
Touch pad unlock
below the touch pad is an on/off button/switch.... try that...
then, if that doesn't work, restart the computer, try again....
or... if all else fails...
Plug in a usb mouse, navigate to
Start >
>Control Panel
>Hardware & Sound Devices
>Mouse/pointer devices... check to see that the touchpad is enabled.
Jul 06, 2010 | Compaq Presario CQ60-220US PC Laptop
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
I am using my phone to ask this question.
the touch pad is usually controlled by synaptic.
To turn it on back, press start menu from your key board and scroll to control panel.
From control panel, use the tab button to select the icons on control panel and go to mouse.
From mouse, use your keyboard to control to device settings.
From device settings, you would see synaptics touch pad, then press enable and that's all.
You touch pad would then be enabled again.
All the best.
Jan 05, 2010 | HP Compaq Presario 2200 Notebook
Mousepad won't respond
go to control panel, performance and maintence, hardware, device manager, find your mouse, and then disable , then enable, if this dont work, update driver, also make sure it is turned on, go to control panel, mouses and keyboards, and make sure it is enabled there first.,
Jun 02, 2009 | HP Compaq Business Notebook NX9005...
Compaq Presario CQ50 touchpad won't work.
Click on Start menu, click Control Panel, under Hardware and Sounds click Mouse. Once the mouse window is open click the last tab that says Device Settings. Make sure the Synaptics TouchPad V7.0 is Enabled. If it's not, then enable it by clicking at enable. Also double check your speed on the mouse pad to make sure it's not set to slow.
Mar 26, 2009 | HP Compaq Presario CQ50-210US Notebook
Laptop mouse
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Mar 15, 2008 | Acer Aspire One PC Notebook
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
