Question about Whirlpool Duet GHW9150P Front Load Washer
Error code F02 on whirlpool duet washer - Whirlpool Duet GHW9150P Front Load Washer
  • 10 more comments
  • Paula Hagstrom Jul 08, 2008
    I am having same problem with my front load whirlpool.
  • kcg061 Jul 09, 2008
    I keep getting the F02 code , then I'll push pause,then start, it will run for a little,and I'll get the SUD code the machine will then lock you out. thats when I unplug the stupid thing, wait an hour plug it back in start the machine over and PRAY! According to the manual code F02 means the pump is bad. I have watched the machine for long periods and the pump seems to be working fine with the water leaving the machine as usual.
  • ari6 Jul 10, 2008
    I'm getting the same error code but after turning off it will then run well for several days.
    thanks
  • Anonymous Jul 17, 2008
    F 02 code if I unplug it it still does the same thing we took bottom panel off nothing is in there which we got a wash cloth out of there before and it started working fine it will start a little water will drain and then it stops again
  • jeffreyblake Aug 09, 2008
    error code F the washer is not draing or spinning and it looks as if the tub itself is off balance. Under the rubber ring is also filled with water. What is the average warranty on this washer? Mine also leaks every time I wash towels. I have done nothing to solve the problem still trying to find the paperwork
    Frustrated
  • bigdaddy1192 Aug 09, 2008
    My whirlpool duet washer is almost 3 yrs old. We do alot of laundry, 5 & 6 loads a day, so the machine is always going. Up unitl today I haven't had any real problems with the machine, occasionally the SUD code, & usually that load had washclothes from my kids bathroom in it. You know what kids do when they get new bottles of shampoo, especially little girls, they pour them out. That was my explanation for the SUD code. But today I heard a beep & discovered the F 02 code. I of course couldn't find my manual so I came to the internet for a solution & thankfully I found one. I am waiting on the machine to drain so that I can take the panel off and clean the filter. I will let you know if cleaning the filter works, or if I am going to have to replace the pump.
  • Sonyachbc Sep 29, 2008
    Where is the filter the back or the front of the washer? I need help!
  • Anonymous Apr 21, 2009
    F 02 Code. Did a load with cheap bath mat. Bath mat fell apart, got everywhere inside. Drain hose clear. Will start loads, but won't finish. First it will say SUD. Then it will say F 02 code.
  • char2730 Apr 22, 2009
    where is the filter at on the woolpool front loader washer? the door wont unlock.
  • Anonymous May 02, 2009
    I had this same problem and talking out this filter worked. I actually found one of my wife's socks clogged in the filter. Thanks.
  • amajamacay
    amajamacay Jun 26, 2012
    All this info just saved my machine!!!! Thank you thank you thank you!!!!
  • ann colburn
    ann colburn Mar 19, 2014
    Me too. How did you fix?
Pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business.
Posted on Apr 18, 2009
  • aschoening Feb 27, 2013
    Bless, you for the solution. I wondered why I was getting the rotten egg smell. GROSS! I had no idea there was a strainer since the unit was here when we purchased the house :)
  • Ryan Saul
    Ryan Saul Feb 10, 2014
    Thank you so much! This did the trick.
    Problem Solver:
I was having the same problem with my 4-5 yr old machine
my husband took the bottom panel off and cleaned out the
filter before the pump...pulled about $3.75 in coins, nails,
a piece of sponge and various other items
See the link below for some details
http://www.applianceblog.com/mainforums/archive/index.php/t-4377.html
Posted on Jul 11, 2008
Thanks to advice from solutions #3 and #6 my washer is working great! I was getting flashing codes F02 and sud, my washer wouldn't drain or finish cycle or unlock. To unlock I unplugged washer to reset, then started new cycle, then pressed pause twice to stop and it unlocked the door. I then followed advice for solution #3 to clean out filter and found two insoles from my kids shoes I had washed. It was very easy to do! ...NOTE! Solution #6 mentions lots of water...they are not kidding! be prepared with towels or slide a pan under the washer before unscrewing front of filter
Posted on Apr 30, 2009
GREAT!!!!! Thank YOU "EVERYONE" ................"IT WORKED" I had the F02 code coming up on my duet washer, My husband unscrewed the 2 screws on the bottom, unscrewed & opened the white nob and a thin green scrubbie was wrapped around it covering all the drain holes....plus we found 2 screws, a safety pin & a .25!!!!!!!!!! Whhhaaaa Laaaa!!!!! RUNS GREAT now & no error codes............
Christopher & Angela :o)
Posted on Dec 24, 2009
Just cleaned mine out and found several bobbypins, almost a $1 in change and a bunch of gunk. While we were at it hubby asked if I wanted to do the dryer to so he took off the front. WOOOOO! I vaccuumed up almost $2 in change and 3 dust containers on my vaccuum full of lint!! Might be a good idea to do the dryer too when you do the washer!!
Posted on Jun 26, 2010
The filter is more of a strainer. It is located behind the front cover. It's white, in the bottom and center. Mine had all kinds of stuff in it.
Posted on Nov 15, 2008
Please help. Where is the filter? Is it in the back of the washer?
Posted on Sep 29, 2008
    New Friend:
My husband told me to just call someone to fix it but i thought why if there telling me what to do so i tried it and it worked it had a sock , rubber bands and 4 band-aids and lots off gooo started working again saved some money and only took about 5 min the only thing that my tub had water so i had lots off water all over my kitchen if you try this at least take out water from tub so you wont have such a big spill... THANKS ALLOT TO EVERYONE THAT POSTED THE SOLUTION...
Posted on Mar 30, 2013
Thanks, Everything works perfectly now!
We especially appreciated the comment about going upstair with wife after the repairs :)
Posted on Jul 04, 2011
That was one of the most satisfying fixes EVER. I popped the cover off, cleared the filter and the washer is running again in less than 20 minutes.
Found: two Purex 3 in 1 laundry sheets (evil!) a one dollar bill, $2.58 in change, oddly enough, an allen wrench like the poster in #11, a small wing nut and a ring.
Posted on Jul 21, 2010
Jsrock you do rock!! We have a Maytag Epic Front loading washer and the door was locked, would not open, and the water wouldn't drain. Then the computer acted as if it was going to die.
I checked the drain filter and sure enough, a pair of rubber gloves (I'm a hairstylist and must have left them in some towels that were in the washer), a pen, some lint, and some twist ties...replaced the drain pump access cover and performed the functions you mentioned, and wala!!!! It ran a load of clothes and worked beautifully. Had an apt scheduled for Maytag pro to come out..called tonight to cancel and the trip charge was $ 90 alone...not including parts and labor!!! yay Fixya~~ ALSO! I am so mechanically challenged and when I saw the ladies post that her and her 4 yr old performed this fix, I knew with God on my team, I could do it too!! It really was easy and my husband was stunned when he came home and it was fixed!!! Thank you so much for this valuable information!
Posted on Dec 08, 2009
Are the 3 screws behind the door itself? And are they like star shaped heads, not 4 way? My husband is gone on a hunting trip and with 5 kids cant do without a washer for long.
Posted on Dec 03, 2009
Great -Glad I came across this - 3 screws and turn the white knob - found an allen wrench, lint, cap to something, and 3.05 in change!
PS be prepared for a lot of water if it won't drain on its own!
Thanks
Posted on Nov 02, 2008
B 4 u go buy a $300 dollar pump check the filter mine had washcloths, pencils , rocks, guitar picks,money(6 cents)and prob a big culprit (color catchers) by clorox. works like new and no codes. :)
bubba.
Posted on Aug 07, 2008
localwonder
  • 6784 Answers
SOURCE: whirlpool duet washer will not spin out water,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Aug 13, 2009
SOURCE: Whirlpool Duet Washer Trouble Code F25
Best Solution is to return it and buy another kind like LG or something
Posted on Mar 01, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 09, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
Potential Causes
Posted on Oct 16, 2009
SOURCE: whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Posted on Jan 22, 2010
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
What does F02 code on duet washer mean?
Jul 28, 2014 | Whirlpool duet Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
15,622 people viewed this question
Dan Webster
Dan Webster
Sal De
