Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
On button on machine does not come on. all other lights come on when pressed.
  • 312 Answers
Hi, I don't believe that the "on" button will come on if the unit is in program mode. I used to have one of these. If memory serves me correctly, and your unit is not broken, then if you shut off the program, push it once, you should be able to turn it on manually.
Your coffee maker is had a 3 year warranty from Cuisinart. Here is the link to the user manual below.
Best, Mark
http://www.cuisinart.com/share/pdf/manuals/dgb-550bk.pdf
Posted on Dec 29, 2010
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
How do you set the time as well as the timer? I have looked but can not find the manual.
Good Afternoon,
Programming Your Coffee Machine
• Plug in your appliance: the display will light up briefly in blue, blink "8888" and then remain
fixed.
• Press the O/I button if you wish to make coffee without using the programmable mode.
• The display will light up in blue and alternately show "ON" and the current time.
• Press the O/I button to shut off the coffee machine. The display will no longer be lit.
Setting and Adjusting the Clock
• The machine must be "off".
• Press and hold the prog button (o) for 3 seconds: the hours will blink "88 _ _".
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink" XX 88".
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink "prog" for about 1 second, followed
by "8888".
• Press the prog button briefly: the hours will blink "88 _ _".
• Press the prog button briefly: the minutes will blink "XX 88".
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a " ".
• Press the h/min button to cancel the programming.
Click the link below for the maunal:
http://www.krupsusa.com/NR/rdonlyres/A50B1840-2CD9-44C1-87E8-260B92D96D3A/7244/FME124_FMF345_usa.pdf
Hope this helps!
zeppelinx12
Feb 23, 2011 | Krups FME2 Coffee Maker
Child lock is stuck on and machine won't start
Does this help?
If you wish to prevent small children or pets
from climbing into the machine, you can
deactivate the automatic door opening
function.
1. Turn off the machine using the main power
switch.
2. Press the Door Open button while
simultaneously pressing the main power
switch. Release the buttons.
3. Press the Key button and the red field goes
out. Automatic door opening is now
deactivated.
4. Press the Start/Stop button to save the
setting.
If you want to reactivate the function, follow
the instructions above, but when you press
the Key button (point 3) the red fields light up.
Store the setting by pressing the Start/Stop
button.
Do let us know if it does
regards
Feb 01, 2011 | Asko W640
The alarm light to empty the coffe grounds drawer AND the descaling light flash alternately I cleaned the brew group. Machine comes ready, but when I press to make a coffee it comes back with alternate...
Hi, the problem with your machine is with the grinder motor (not working).As soon as you press the coffee the CPU senses the motor is out of circuit and the lights start flashing alternately.
You can test it by doing this. Press and hold the steam button and switch on the machine, you will see the lights going around in anticlockwise direction. Release the button then turn the dial to left (Min) and press the steam button the grinder should work. The dial on the right (Max) the brew group will come up..and half way it will come back to normal position. Press the coffee button in that position will work the pump. Servicecenter can fix this if the machine is less than 2 year old FOC.
Oct 10, 2010 | Saeco Odea Go
I have just changed the brown control board and now i have a fault code 9
Hi and welcome to FixYa. I am Kelly.
You did not provide a make and model number so here is my best model to problem guess....
Your new control board is missing the size information.
AQUASMART-SIZE-SETTING. Size information must be programmed when a Motor Control Module or Display Module has been replaced. If the size is not set, the display will show fault code 9, or the water levels and wash actions will be incorrect. If the machine displays fault code 9, the machine must be switched off at the wall and then back on again before it can be sized.
Setting the size:
Unplug at the wall and then re-plug it in.
Press and hold Temp Up, then press Power. Wait for the 4 beeps, then set your machine size as follows to YOUR machine size:
5/5.5kg machines - press Temp Up. Cold led should light.
6/6.5kg machines - press Water Up. Low water led should light.
7/7.5kg machines - press Spin Speed up. Spin hold led should light.
Power off, try a programme.
Thanks for using FixYa!
_____________________________________
From the Tech Sheet:
IWL12 and GWL 11 are different models. One of the two procedures will work for your machine.
The machine size must be set into the machine
memory if a Motor Controller or Display Module has
been changed.
To set the size:
1. Turn the power on at the power point and off
at the console.
2. IWL12 - Press and hold the FABRIC CARE
button, then press the POWER button. This
will present a set of options in the LCD
screen. The LCD screen has within it a
number of options. Push the Adjust button to
highlight the 650mm (L) machine size.
Pushing the POWER button will lock the size
into the module’s memory.
GWL11 – Press and hold the WASH TEMP
UP button then press the POWER button.
Press the SPIN SPEED UP button (the HOLD
LED should be on.)
3. Press the POWER button to return to normal
operation.
Kelly
Mar 20, 2010 | Washing Machines
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
On my ge answering machine, the CL red light keeps flashing even though there is zero msg. so how do I clear this CL red light flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Nov 02, 2009 | Uniden Cordless Phone
How do I program an astoria SAE-2 espresso machine?
Look behind the right steam valve, you will have to remove the front top panel, there might be a small toggle switch, note the position. If switch is not there then it is on the black CPU box. Press the program/stop button if all lights come on move forward if not then move the toggle switch to opposite side and press program button.
When all four lights are on press a button when you get the desired volume press stop, continue until buttons are programed then move toggle back to original lock position.
Sep 28, 2009 | Astoria Argenta SAE-2 Espresso Machine
Directions on programing the Divina espresso machine
Depending on the model, if you remove the top cover you will find a small toggle switch on the right corner of the machine, just above the fitting for the steam valve, switch it on, then press prog/stop button all the lights will be on , press shot button when you get desired volume press shot button again or press stop button. When you are dont programming return switch to off position.
Mar 25, 2009 | Astoria Divina SAE-1 Espresso Machine
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
87 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
