Question about HP Compaq NC6400 Business Notebook
Compaq 615 touch pad not working... it is showing in the device manager. but not responding...
  • 14 Answers
SOURCE: touch pad not detected in device manager-hardware
if you do a "san for hardware changes" in the device manager and the touchpad will not show up it is a hardware problem. Otherwise find the correct drivers for the device and install them. Or check the mouse settings in the control pannel and see if you de selected something there.
Posted on Jun 26, 2009
Pyrhyc
  • 2028 Answers
SOURCE: Panasonic cf-29 Touch screen not working
May be a conection problem. I had a cf72 that the conection had come loose at the motherboard. If its not the conection it may be the scvreen itself.
Posted on Jun 10, 2008
Pyrhyc
  • 2028 Answers
SOURCE: touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Posted on Jul 20, 2008
SOURCE: NEC Versa VY22X/RX-L TOUCH-PAD FAILURE
perpy,, this is brian ...the answer to your prob is to go to your nearest technician ,,or if your not afraid to open ur laptop,,just clean it,,maybe it is not clean or it may have a thick dust...just try it bro
Posted on Jan 15, 2009
geo_jonas
  • 555 Answers
SOURCE: Acer Aspire 6930 Touch pad not found
Please reinstall your Touch Pad Synaptics Pointing Device Driver then restart your machine.
Thanks
Posted on Aug 27, 2009
How can i make my cursor respond using the inbuilt touch . it stopped and i have to use mouse
You have to reload the software and the drivers for the touch pad. Often the name of the drivers and the program that runs the touch screen may not seem apparent. If you have the disks that came with the computer, start with the drivers and utilities disk and re-install all driver files. That should get the hardware listed. you should also check your device manager (start button, right click computer, click properties, click on hardware tab and then click on device manager) for any yellow or red icons. The device manager will show you on a tree, all the hardware working on your computer.
Apr 10, 2013 | Dell Vostro 1015 Laptop
How to turn cq56 touch pad on/off
You might try to touch the screen/pad and hold your finger down for 5 seconds. Also, lok in Device Manager to ensure that it is enabled, else it will not work.
Cheers!
-a.
Apr 09, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Hi i cant disable my touch pad on hp cq42
Try going into device manager by right clicking on 'my computer' or 'computer' in the start menu and then clicking properties, then look for device manager. Your touch pad should be listed under 'mice and other pointing devices' or something similar, depending on your version of windows. Right click it, then click disable on the menu that pops up.
May 29, 2011 | HP Compaq Presario V2000 Notebook
Both the buttons of my Compaq Presario C700 touchpad stopped working all of a sudden.
You have perhaps a CD for your presario Compaq computer. Try to insert that in your CD rom and look for the touch pad to enable. Or just look for the touch pad in your device manager and enable it. To open the device manager, right click computer and go to properties and click hardware then click device manager. If touch pad is in the list enable it.
Thanks...
Dec 10, 2009 | HP Compaq Presario C700T
Touch pad not working after downloading driver.
install lanch manager
device manager, rigth click your Mycomputer, manage, Device manager...
Jun 02, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Mouse is not responding at all
you need to go to device manager...
right click "my Computer"
select "manage"
select "device manager"
click the + sign for "mice and other pointing devices"
select your touch pad...
try to enable it or find what is wrong from there
You'll need a USB mouse or something of that ilk to do it.
good luck
Apr 10, 2009 | Lenovo 3000 N500 Notebook
I ve compaq c700 c772tu lap top...it does not have wifi software
You should be able to download drivers (the programs that make the hardware work) from Compaq from this site. You'll have to transfer them to the laptop via flash drive or other such device, and run each file needed individually, following any instructions. To be sure that you have drivers for everything installed, you can right-click on "My Computer" and select "Manage," then go to "device manager" on the left pane, which will show you all the hardware that windows sees attached. Anything with a yellow exclamation mark (probably) needs a driver - double click on it to see more information.
Jan 17, 2009 | Compaq Presario C700T Notebook
Touchpad not working
right click on my computer>properties>hardware tab>device manager> and look down the list for mice and pointing devices.
Click the '+' sign and see if your touchpad is listed, see if it is dissabled, if it's there if not right click on it select uninstall.
Restart pc and it will find touchpad and install drivers, all should then be ok.
If the device is not showing, then there may be a hardware fault
Aug 18, 2008 | HP Compaq Presario v3000z Notebook
Touch pad driver.
Jul 20, 2008 | HP Compaq nc6220 Notebook
HP Compaq NC6400 Business Notebook Logo
1,155 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
