Question about Husqvarna Garden
This husqvarna YTh1742 wont start Replaced battery, no lights, starter moter is not engaging
  • 16 Answers
SOURCE: Husqvarna LT2042
the soneloid switch sends power to starter . check power on red wire on starter when key on full .if no power must be soneloid switch problem even though it clicks
Posted on Nov 11, 2008
  • 246 Answers
SOURCE: Mower deck does not engage
Hello:
>>Check the Voltage from the Stator/Charging Coils.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>A Bad Stator/Charging Coil will Cause the Problem you Described.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 81 Answers
SOURCE: Starter flywheel is not engaging motor
If you blew a fuse you could have a grounded wire someplace. Check the wiring on the solinoid, on the battery, on the lights and anyplace there could have been a bear spot rubbed. If the flywheel does not engage check the flywheel gear on the end of the started to see if it is chewed and worn. These can be replaced easily,
Posted on Jun 20, 2009
  • 135 Answers
SOURCE: Cub Cadet 1320 wont start. Has new battery.
Not enough voltage,or starter bendix failing to engage
Posted on Aug 13, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Husqvarna yth2348 lawn tractor. It starts fine, but
You didn't mention how long it worked with the new battery so here are a couple of things to try. Using your car/truck and a set of jumper cables if you have them, see if it will start,just be sure that they are hooked up properly.
Use a volt meter and test the battery. It should have at least 12 volts. Get the engine started and at full throttle, again test the battery, it should be showing 13 to 14 volts indicating that it is charging. If not, your charging system is the culprit. If charging system is good, then it may well be the starter, Remove the starter and take it to a lawnmower repair shop or do-it-yourself auto parts store and have it checked. The starters are VERY expensive depending on the brand of the engine so you want to be certain that it is bad before buying a new one.
If all this is good and/or it sounds like the engine makes about a half of a turn before bogging down and not starting, it could well be that your valves need adjusting or in worst case scenario, your automatic compression release inside the engine has failed
Posted on Sep 19, 2009
My husqvarna riding mower wont start it just makes clicking noise i replaced my battery and it does the same thing
Check for proper voltage at the starter terminal. If there your starter is bad.
Aug 26, 2014 | Husqvarna Garden
2002 yukon wont start drove it allday yesterday and last night .woke up headed to to work wouldn't start tried jumping it still kno start replace battery and still wont start
Is the starter engaging when you jump start it? You say you replaced the battery, is the cable ends clean? If the starter is engaging you have other problems, if its not then check out the starter/cables. Good luck!
Dec 04, 2013 | Cars & Trucks
Starter motor solenoid wont engage
There is condenser shaped part attched to the starter moter this is the part which makes the starter moter to spin and when it is stuck the moter does not spin you can check it by one person sitting in the car holding the key to start position and another one hit it softly with some spanner or something The starter moter will move there is a small gear in it which requires replace ment Or the other possible reason can be the carbon brushes in the starter moter are worn out or the place where these brushes touch on armature the place is worn out that Y ou will only come to know when you will take the moter away from the engine Lastly I hope you might have checked your battery that it is giving sufficient current to the moter
Aug 16, 2012 | 2003 Volkswagen Jetta TDI
2003 dyna starter turns but wont engage, new battery fitted
Hi Anonymous, lift up rubber boot on positive cable to starter, unplug starter relay wire usually green, with a jumper wire connected to positive battery cable starter stud, touch blade connecter on starter where starter relay wire was removed. If starter engages and turns over engine then your starter relay is bad. If starter activates but does not engage then your starter drive/clutch is bad. Good luck
Jan 22, 2012 | Cars & Trucks
The electric starter spinns but wont engage to turn 6-5 hp briggs and strattanengine on my huskvarna lawn mower
hi there
svseanachai
have you had the battery out ? if so did you refit the battery back in , with the proper connections to battery - reversed connections at battery makes starter spin but starter clutch wont engage - have seen this on b/s 16 hp vee twin
if this is ok check the starter clutch / helix and gear they may be faulty or stuck
have a look let me know
cheers hope it helps
pauly46
dont fprget the thumbs rating
Jun 02, 2011 | Husqvarna 675 hp 21" Honda Rear Bag Push...
2002 VW Jetta won't start
Check the battery out put to see if it is at least 12.25 volts(may need to have it load checked).If the battery checks good,remove battery cables and clean them real shiney,also the battery terminals,and replace them back on the battery,WARNING,DO NOT DISCONNET THE BATTERY WITHOUT PLUGING A 12 VOLT POWER SOURSE INTO THE CIGARET LIGHTER PLUG,OR EQUAL.If you do not plug in a power sourse to the car,the computer will loose all it`s memory,and will have to go to the dealer to be reflashed.
Sep 21, 2009 | 2002 Volkswagen Jetta TDI
Wont start
tap the solenoid on the starter probably a bad starter solenoid.
Mar 18, 2009 | 1997 Ford Expedition
Wont start
Sounds the starter is no good (sometimes they'll work intermittently for a while before they totally **** out). Of course it could just be a starter wiring problem (sending wire).
Mar 12, 2009 | 1997 Ford Expedition
Husqvarna LT2042
Oct 18, 2008 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
50 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
