Question about Sharper Image Deluxe Shiatsu Back Massage Cushion
I just bought it from Costco brought it home and plugged it in and remote doesn't work
I have black lines on the left side of my vizio m550sl. Sometimes the remote doesn't work. Sometimes the volume goes to max
I brought mine back to Costco. It was doing the same things and more, its a defect or seems to be. They took it back a year later.
Oct 07, 2016 | Vizio Televison & Video
My problem is I have a electric fireplace the insert is a colemen and the heater stoped I bought it a Costco about 4 years ago
It may need repairing, do not take risks trying to fix it without an expert. But its 4 years old so its better to replace it with new.
Dec 15, 2013 | Leisure HOMEPRIDE Electric Fireplace...
I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
Oct 20, 2012 | Bose Cinemate Digital Home Theater System...
Bought a 36" oscillating tower fan model FZ10-9LR
this happen to me one i just went in bought new fan took the good remote out and gave them back the bad one brought it all back and got my money back.good luck
Aug 05, 2011 | Hampton Bay Dryers
4 fans bought in April from Costco and pac tested. 1 makes a a funny sound when plugged and does not work.. Can this be brought to a centre to be repaired as a callout cost 55 pounds Many thanks Mrs...
It sounds like you bought these items online from Costco, unless you have a Costco close by. Using the term "pounds" tells me you are in England someplace. A repair shop should be able to repair the problem easily and quickly. The noise you hear might be from the motor that is trying to start. Did you try a different power supply to see if the problem is your power outlet? You might try that. Cheers.
Jul 16, 2011 | Honeywell Dryers
Cannot remove the 'store' settings from 55 inch vizio bought at costco today When i push the "OK" button on the remote it 'thinks' that I'm pushing the 'menu' button and gives me the 'menu'...
Unplug the set for 20 minutes then plug it back in and turn it on. You should see a setting that says HOME____STORE on the screen. Make sure you high-lite HOME. Then continue on.
Dec 27, 2010 | Vizio XVT553SV 55 in. LCD TV
Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital antener. all works but I can't get any channel 9 stations no matter how many times I rescan channels?
''Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital ''
Poor English!
It should read; ''Bought a Coles $259 Nu-tec DVD/Tv combo, brought it home and set it up with a indoor digital ......''
Jun 12, 2010 | Televison & Video
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
New bright 19.2v nicd battery problem
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Jan 17, 2009 | New Bright Remote Control Toyota FJ...
Stainless Steel 4 Slice Toaster TT49
uk power and power in Lebanon are not the same ,if you get your friend to go with you you will get a replacement or refund Costco are good this way if you remember the date when you got it it will help,costco will help you
Jun 17, 2017 | Breville CT40 Retro Classic 4-Slice...
Sharper Image Deluxe Shiatsu Back Massage Cushion Logo
44 people viewed this question
Top Sharper Image Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sharper Image Health and Beauty Expert? Answer questions, earn points and help others
