Question about Karcher 2500 PSI Pressure Washer
Karcher kb 2020
When i turn the on/off switch nothing happens
  • 33 Answers
A/c or gas? if a/c you probably have a bad switch. if gasoline you could have no connection to kill wire to coil or the switch is bad.
Posted on Apr 21, 2009
What to try when karcher pressure washer wont start//?
unit may have either a bad power switch or stuck flow switch normally located at the inlet of pump inside where you hook up the garden hose
Aug 07, 2014 | Karcher Garden
Hi, I have a Karcher K2.400 Electric High Pressure Washer. When I pull the handle nothing happens. When I plug the power in the pump does run a few seconds. I also checked the inline filter and that is all...
There is a pressure switch that turns off the pump when it gets to a certain pressure. It sounds like that switch is sticking. The contacts should be closed when you first turn on the pump. If you hold open the trigger when you first turn on the pump and the pump stays on then that pressure switch is most likely the problem. If you turn on the pump with the trigger open and the pump runs for a few seconds and then turns off check for a blocked nozzle.
Jul 28, 2014 | Karcher Electric Pressure Washer - 1600...
Operating Manuals Karcher 302 presser washer
do you want a "how to use the machine" or "parts diagrams" or "how to repair" ?
"how to use" is the same for all pressure washers...........
i guess you own a KB 302 1.994-923.0 but karcher dont list this "operators manual"
this is for the k 370 :
http://www.sparesgiant.com/media/import/karcher/k370%20op%20man.pdf
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Jul 12, 2013 | Garden
Can't switch Karcher window vac off
I had the same problem and I let the battery run down to stop it cycling on and off. My husband investigated it and found that there is a fault with the on board battery charge sensing circuit. (when the charge is about 10 to 15 % remaining the onboard ic controller cycles the unit on and off, irrespective of the switch. He checked it by cutting wires to the switch and it still cycled off and on so the switch was not faulty.
He put it all back together and said to charge it before it gets too low. If it cycles on and off it probably needs a re charge at that point.
Unfortunately there is no battery level indicator on the tool and nothing to suggest in the manual of what may happen when battery is flattening.
I am taking this up with Karcher as I only used it three times so far and it it was not a cheap gadget. Hope this helps
Mar 08, 2013 | Karcher WV50 Window Vacuum
After sitting for several weeks, I plugged my electric 1500 PSI unit and nothing happened. Usually there is a pulse in the motor and it waits for the trigger to flow water to reinitialize the pump. ...
this Karcher unit have a termal overload in the motor but your problem can be cause by a pressure switch the shutt on and off the motor when you stop spraying.
Aug 15, 2010 | Karcher K2.26 Electric Power Washer
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Apr 04, 2010 | Karcher K DS 5500 Vacuum
I have a Karcher B402 Pressure Washer and when i plug it in and turn it on - nothing happens, not a sound. I have checked the fuse and the plug itself and this did not help. I contacted a service...
hi if you remove the torx screws that hold the electric box on and then bypas the on/off switch join wires together. and check the pressure swicth if it is the pressure switch you can bypass this but the machine wont shut down regards
Jan 19, 2010 | Karcher K2.26 Electric Power Washer
The engine on my Karcher K2.26 turns on when you turn the switch and continues to run rather than just when you pull the wand trigger. Lower pressure also results.Any solutions?
yea mate ya bypass will be stuck(the little valve that turns the unit on or off) also if not that there is a little micro switch attached to the valve this may of dislodged for some reason... commonly happens if unit has sat for a period of time not used
regards
brad
Sep 07, 2009 | Karcher K2.26 Electric Power Washer
Karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
257 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
