Question about D-Link Dcs-3110 Megapixel Camera DCS-3110 Network Camera
What is ip default dcs-3110 network camera? - D-Link Dcs-3110 Megapixel Camera DCS-3110 Network Camera
SOURCE: DCS reset
Push the reset button on the back of the camera
Posted on Feb 23, 2008
SOURCE: Wireless installation for DCS-5220
check wep and wap security in your camera.
check if your wireless signal is good
Posted on Jul 15, 2008
  • 3 Answers
SOURCE: IP camera keeps resets itself
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
Posted on Sep 20, 2008
  • 93 Answers
SOURCE: Can't find IP Address
Helo,
You want to find the localserver ip address U go to cmd- and then type ipconfig .U want the internet ip address u go to this site ip-detail
Posted on Jun 05, 2009
  • 477 Answers
SOURCE: what is the default ip address of D-Link DCS-3220
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Posted on Jul 09, 2009
How to recover corrupted firmware for IP camera DCS-5220?
http://support.dlink.com/ProductInfo.aspx?m=DCS-5220
Go to this site and download the drivers
Then
Uninstall old drivers and install new ones
Jan 06, 2017 | D-Link DCS-5220 Network Camera
Hi!! How can I change IP address on DCS-3220 security camera?
DCS-3220 is fixed IP security camera !!
can't change its ip !!!
Jun 14, 2011 | D-Link DCS-3220 Network Camera
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
Password and user id
Reset the camera by holding the reset button for 3 seconds (use a paper clip in the hole marked "Reset" on the back). The camera will then reset to all default settings, including an IP address of 192.168.0.20.
Nov 19, 2007 | D-Link DCS-900W Network Camera
DCS reset
Oct 05, 2007 | D-Link Express DCS-900 Network Camera
D-Link Dcs-3110 Megapixel Camera DCS-3110 Network Camera Logo
147 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
