Question about Fujitsu Heating & Cooling
I have a karda heat pump and on the display it say E1, is this an easy fix and if so how do i fix it. i have tried every thing the manual says
  • Barrett Palumbo
    Barrett Palumbo Dec 29, 2010
    Sorry to read about your issues.
    But you really need to give us the model, of your unit. It kinda helps us to help you.
Yes open the 1st pannel and replace it
Posted on Dec 29, 2010
I got the E1 at the display I understand that is sensor on how kan i get it of so i kan get the heat back on
This error is a high limit sensor failure. IT could be lack of water flow, check the filters, make sure all the jets are on. Check the pump impellors. IF there is nothing wrong, change the sensors on the heater manifold. There are usually two and they look like silver cylinders with wire coming out of them.
Feb 09, 2017 | Heating & Cooling
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
Dado
Jul 02, 2015 | Bosch Dryers
Whirlpool dishwasher ADG 7800 manual
Spray pump bearing ... replace main spray pump
Aug 30, 2014 | Dishwashers
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
Jun 17, 2014 | Ingram's Water and Air ComfortStar Mini...
What does E1 error code on a Karda heat pump, model KSAC-18HRDCI mean as there is nothing in the manual about error codes. How do you clear it?
I have worked this out. There is a 20A fuse inside the compressor(outside) unit, it is a glass fuse that has a sleeve over it and is soldered to the PCB. They appear to have a manufacturing fault and 'blow' at a lower current than the 20A, Just the edge of the fuse link is not properly bonded to the end cap. On inspection they don't look blown, but test open circuit. Was a relatively easy fix with a soldering iron and a new 20A fuse. You can find this fuse on the gas piping end of the compressor.
Sep 12, 2011 | Heating & Cooling
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Karda heat pump not working and displaying E1 on the screen
Did you ever get a solution to this? Mine's doing this today!!! I can't find anything in the user manual to help, either.
Oct 29, 2009 | Heating & Cooling
Simplicity air conditioner
I had an e1 error, the fan was spinning but the compressor dosen't.  I don't know witch step i made fix the problem but try it.  I unplug the air conditioning for few minutes, unplug the control panel, get every things  back and it's work fine.I wish that can help youFrançois
Jul 10, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
244 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
