Question about EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard
My problem here is.. my computer wont produce music..and i thnk its because of the multimedia audio controller.. can smeone send me a link on it?? motherboard is... p4vmm2
    President:
  • 1,812 Answers
May be your audio device and speaker problem,do all the steep
Check from task menu bar bottom right side corner check the volume icon at (bottom right corner)task menu bar. Ensure that check off onthe mute, or
. Volume is MUTE / Low (in Volume Controller).
. Audio drivers have installed.
To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers).
6. If not, insert the motherboard CD, browse>select audio driver>install with audio driver.After completion, restart computer and check. If same ,i will give the sugetin to purchase to purchase usb audio drive my problem here is.. my computer wont produce - shibuda_26.jpg
Hope it will help you.
Posted on Dec 29, 2010
I cannot find correct driver multi media audio controller using windows7
You can download the device drivers from MSI WEB support site, select your model motherboard Windowa 7 drivers to download :- http://www.msi.com/index.php?func=downloadindex
Mar 02, 2013 | MSI : K8N NEO4 Platinum SLI/S939/nForce4...
I can start the program but the music skips every 5 seconds or so, and the video does too.
Computers require the entire hardware software components to produce results. For example, a computer from which multimedia is requested has to have an extensive graphics units, sound cards, video cards, as mentionable hadware. Once the computer were powerod on should have the programs that makes media play without skipping. For example media on the computer would display least without malfunctioning on music video programs. Multimeida programs as called, are acquirable at retail market that captures the media to display without errors. Also any existing malfunctions on computer media is restorable with multimedia programs. Usually the computer least expects to display malfunction onless that the recorded audio sound videos were malfunct in which instance requires restoration attainable with expert programs. Observe that the condition caused is least from the computer hardwares structures or on the software programs structures. Usually the hardware devices makes multimedia display only shy of an extensive impression. Recently innovated computers are multimedia enabled least require improvisments once acquired. Usually the owner operator of the device would require adjusting the computer to attain requisite functions mentioned. For example, computers that are video, audio, media tasked depending on the compartibilities of alternate devices on internets or media from cameras that are encoded would require convertor programs to capture display. Depending on the requirements or resourcefulness requested from the computer devices, an expert support consultation would ascertain the entire missing programs from which to attain adjustments to suit owners operators task requirements.
Feb 19, 2011 | YouTube Videos
My microphone isn't working. I've checked the control panel, and I have the microphone not muted and set at medium level. This happens a lot, and I can never remember what it is I am doing wrong.
Hi ,
Test the record function on the notebook PC
  1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
  2. Click Record (the red dot) and speak into the microphone.
  3. When you are finished recording, click Stop (the gray rectangle).
  4. To play back the recording, click Play (the gray arrow pointing to the right).
  5. If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
  1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .A Volume Control or Master Volume window opens.
  2. Click Options , and then Properties .
  3. Select Recording , and make sure Microphone is selected.
  4. Click OK . The Volume Control window should change to a Recording Gain Control window.
  5. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
  6. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
  1. Access sound properties:
    • In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
    • In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
  2. Click the Audio tab.
  3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
  4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
  5. Click OK .
  6. Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
Jan 29, 2010 | Sony ACID Music Studio 7
Ethernet Controller, Multimedia Audio Controller and SVGA
Your drivers are not properly or not at all.If you give me you email address i can send them to you or you can call dell and tell them you need a driver cd .
Jun 17, 2009 | Dell Precision 470 PC Desktop
Multimedia audio controller
Try Intel's Web site or try these web sites they are free.
www.drivers.com
www.driverguide.com
Good Luck
Feb 17, 2009 | Intel Premier Resources 6-Channel 32-Bit...
Serial Number on Magix Music Maker
hey, here is the best solution for you. if you want to download magix audio cleaning lab 12 with serial no check out the following links
MAGIX AUDIO CLEANING 12 PART-01
MAGIX AUDIO CLEANING 12 PART-02
or if you want to download MAGIX Music Maker 14 Producer Edition with serial, please check out the following link
MAGIX MUSIC MAKER PART-01
MAGIX MUSIC MAKER PART-02
Jan 13, 2009 | Magix Audio Cleaning Lab 2005 for PC
HP Compaq nx6110 PC Multipule Devices Drivers Not Installed
Go to the compaq website, go to support, downloads, look up your computer, and you should see a list of drivers to download.
Jan 12, 2009 | HP Compaq nx6110 PC Laptop
I have a x-540 speaker system I brought today. Do I need a sound card to make it work with my pc. I hook it up/no sound.
A stereo computer system with resources to produce and record surround sound channels. Such surround sound channels are played or recorded using an audio card added to the computer system, which audio card controls additional speakers and/or microphones. Software for redirecting instructions from existing stereo application programs and sending these instructions to the existing audio device driver and the additional audio device driver is needed. Resources for processing the digital audio data for either extracting surround sound channels from two channel data provided by the application, or for encoding two sets of two channel audio data recorded by the two audio cards is also needed
Dec 02, 2008 | Logitech X-540 Multimedia Surround Sound...
Multimedia audio controller device driver
hi,
i install audio driver but not able to control volume and saw in taskmanager that a yellow mark is on multimedia audio controller .then i install this HD audio drver from realtek at it is working.
thank you for appropriate informaton
ranjan
Apr 20, 2008 | Acer Aspire 5610 Notebook
EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard Logo
118 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
