Question about Siemens Gigaset A140 Cordless Phone
I want pin for registering siemens gigaset AL 140
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
  • 3230 Answers
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
Posted on Apr 02, 2010
fathitkf
  • 1871 Answers
SOURCE: user manual for gigaset ac180 in english
Hi :
I have found this User manual SIEMENS GIGASET AL 180 for you .. Some times a manual for a close product to yours from the same manufacturer can help .
I hope it will help you ..
Please don't forget to rate !
Posted on Jul 09, 2010
SOURCE: I want to register my Siemens Gigaset AL145 Phones
1. On the base station:
press and hold the registration/paging key
(¢ page 1) for min. 3 sec.
2. On the handset:
within 60 sec. of pressing the registration/
paging key
MENU ¢ Settings ¢ OK ¢ Handset ¢ OK ¢ Register HS ¢ OK ¢ Enter the
system PIN of the base station (default is 0000) ¢ OK.
Registering flashes in the display.
Registration takes approx. 1 minute.
Posted on Aug 14, 2010
  • 5227 Answers
SOURCE: My Siemens gigaset A 490
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
Posted on May 27, 2011
I need a user manual, in English, for a Siemens AL 170 Duo phone.
Click HERE and select Siemens AL 180 from the drop down box.
AL 180 has few more functions.
The setup instruction should be the same as AL 170.
Jul 28, 2011 | Lands Phones
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
I want get pin code to register headset to the base
Hi I ave the Siemens giaset AL145 hand display the pls Register.
Pls help us to slove the problem
Regards
Vinod M B
India
+919916134485
Aug 19, 2010 | Siemens Gigaset S450 Cordless Phone
I want to register my Siemens Gigaset AL145 Phones but there are looking for a pin code which I do not have
2. On the handset:
paging key
Jul 11, 2010 | Siemens Gigaset 4000 Phone
Hi therei have a siemens gigaset al/140/A145 telephone the problem I have is all the instructions are in spanish I speak some but read little I need to know how to turn the ringtone up as I cannot hear the...
You can download the manual in a variety of languages from the manufacturer's web site at http://gigaset.com/hq/en/cms/PageCustomerServicesDownloadsManuals.html
Jul 03, 2010 | Audio Players & Recorders
Siemens Gigaset A260 cordless phone fail to register
We've tried to register the Siemens A260 handset to the base but it continues to flash "Base".. and does not work.
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
I have a siemens gigaset S455 i had to take the phone to a new house that im going to rent next month to find out the new phone number back home i need to register the handsets (x2) and cant find the...
unplug the base and press the register button. (it's the round one to the left of the minus button) holding the register button plug the base in and continue to hold the register button for at least two seconds. you should hear a beep. the pin has been reset to 0000.
Dec 07, 2008 | Siemens Gigaset S455 Cordless Phone
System pin unknown
I will email you steps to restore factory default PIN...send me a note
Nov 20, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset A140 Cordless Phone Logo
760 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
