Question about Eureka 2991AVZ Bagless Upright Cyclonic Vacuum
Very loud operation
When running the vacuum the sound is almost deafening. The machine is 6months old and ran like a champion at first. It would even pull itself along from the brush rotation. I used the hose attachements to excess with constuction debris and now because of the noise it makes it hard to use. Yes my wife gave me an I told you so.
I cleaned out the hose, roller assembly, both filters (above cannister and side), and blew out all other spaces that I could see. It helped very little. Did I ruin the motor or did I miss something?
    Scholar:
  • 148 Answers
You have to remove the cover from the motor and check for debri it sounds like something is dragging against the fan which is built on the motor
Posted on Jul 07, 2008
Noise
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson vacuum. From your description, it sounds like the model number you've supplied may not be correct, as DC08 is a cylinder vacuum which doesn't use a belt-driven brush bar. So we can confirm exactly which model you own and take you through some quick diagnostic checks, I'd encourage you to contact us directly. You can reach our experts by calling 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to hearing from you.
Best wishes,
Jack - Dyson Official Online Customer Surpport
http://www.dyson.com
Apr 25, 2013 | Dyson DC08 Cylinder Bagless Canister...
Spinbrush is very loud, barely sprays, spraks flew out the side. It is only 6 months old.
Hope you kept your receipt! That's a warranty item. Your motor is making the sparks. Go to hoovers website find the nearest service center and take the machine and your receipt to them. You'll get a new motor, installed, at no charge because they have a 1 year warranty.
Jan 18, 2013 | Hoover Steam Vac Dual V w/ SpinScrub...
Rainbow motor makes loud noise
Depending on the age of the Rainbow, it could be the bearings. Does the noise happen with just the Rainbow or from the power nozzle?
RainVac
www.rainvac.com
800-523-0510
Mar 10, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My Eureka capture bagless vacuum has just started making a loud siren like sound. It is deafening. what is the problem?
does it smell like burning rubber if not check beater brush it sounds like something may be jammed in it or near where it goes up past beater bar into the vacumn inlet if you do have a burning smell the motor shaft is spinning and thinning the belt and may also be making that sound as shaft spins on loose belt
Dec 26, 2009 | Eureka Capture Upright Vacuum Vacuum
Why does the Eureka capture plus pet lovers put off a loud tornado siren sound when you turn it on. I cleaned the filters checked everything and it sounds like a tornado siren in the south. Email...
I would check your fan and see if any of the blades have been fractured. I had this happen recently when my vacuum caught a screw and the sound and vibration was deafening.
Dec 22, 2009 | Eureka Vacuums
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
Ran over cord and the vacuum shut down, won't
sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Loud noise
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka 2991AVZ Bagless Upright Cyclonic Vacuum Logo
201 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
