Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
WILL NOT BUILD ENOUGH AIR PRESURE AND NEED PRESURE ADJUSTURE FOR THE TOOL THAT YOUR ARE USING
Hard start, acts flooded, turn key a couple of times to build fuel pressure then starts. Runs fine after
hi.fault codes indicate feul presure or leaks.if feul presure is ok and no vacuum leaks at vacuum pipes intake manifold or brakebooster it can be a exhaust leak if no leaks it can be a blocked cat or not enough back presure like exhaust box removed or cat insides removed .hope this helps
Jan 16, 2016 | 2002 Subaru Outback
It runs long enough to dry a load but then when you try to do another one it just buzzes when you push the button to start it. If you wait awhile then it will work,... like it over heated or something.
Hi and welcome to FixYa, I am Kelly
This is showing the symptoms of an air flow problem. I suspect that there is just enough air flow in the unit but when it shuts off the internal temps of the cabinet are providing enough heat to also cause the motor thermal overload to cycle.
You should break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
Additionally inspect the vent ducting inside and outside the of dryer for lint build up. Make sure you go outside the home and check the vent flapper at the through the wall connction for lint build up also. This is often where lint build up problems start and then migrate inward blocking air flow.
If all of the above is good you will have to check the blower wheel mounted on the motor drive shaft for signs of a broken hub or... fan blades. A broken fan will cause poor air flow.
The dryer should provide enough air flow to push a relaxed hand / wrist away from the connection point on the back of the dryer. If you do not have this kind of air flow at the back of the dryer connection you need to find out the cause. I.e. lint build up or a fan problem.
Thanks for choosing FixYa,
Kelly
Jan 18, 2011 | Maytag PYE2300AY Electric Dryer
Looking for the part no. for the Ingersoll Rand mod. RA250E20, presure switch
The pressure switch part no. is 97264550. Where can you buy parts for this model? I need a valve plate.
Aug 26, 2010 | Northern Tool Air Pressure Switch For...
Air conditioner will not turn on
has the charge been tested< these suffer from leaks, have the system leak tested and then repair and recharge.
Oct 09, 2009 | Ford Thunderbird Cars & Trucks
Trouble Bleeding Break Line
you need to hold in the metering valve.when you bleed the front brakes.long as the valve closed off you wont be able to bleed front brakes.better to get extra help.hard to bleed by your self .
Apr 20, 2009 | 1988 Oldsmobile Delta 88
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
74 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
