Question about Vizio VO47L 47 in. LCD TV
47" two yr old Visio
  • jonhartjr Dec 29, 2010
    Yes I would like to attempt replacing this part myself as I've been a PC tech for many yrs. and am accustom to replacing main boards and expansions cards. Can you recommend a vendor where i can purchase the board the TV is a VIZIO 100-240V-4.0A. 50/60HZ model: GV47L FHDTV10A serial #: LHPAEAH1866564 part #: 20240010022 mfg. date: May 2007
    (Parts 607CC-0084D Board) ??
  • jonhartjr Dec 30, 2010
  • 4,889 Answers
This is the second time I have seen this problem this week. Seems like a common issue on Vizio LCDs. Anyways the problem you mentioned indicates that the tv-micro IC has failed. THis is located on the main audo/video board and a component level repair is not possible in this case. The main A/V board has to be replaced and it should cost you around 100-125$. Would you like to do it yourself?
Posted on Dec 29, 2010
  • 1 more comment
  • eagle338
    eagle338 Dec 29, 2010
    Not thats the T-con. Look for a large board at the center. It usually has all the inputs.
  • eagle338
    eagle338 Dec 30, 2010
    T-con means timing control board also known as LCD controller. Its not the main audio/video board.
  • eagle338
    Look for a board that looks like this. It is sometimes hidden by a large metal cover unlike other boards.
    http://www.shopjimmy.com/vizio-3370-0052...
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
47" vizio has sound no
Have you selected the proper input for how you have it configured? If using an HD connection, select the HDMI 1 input. If you are using the coaxial cable connection, then select TV input. If you are using the three RCA inputs (yellow, red, white) then select AV input.
Mar 01, 2011 | Vizio VO47L 47 in. LCD TV
I have a 32 in HDTV LCD,,,used only about 20 times. Started hearing "crackling" noise. Picture is good. What could this be? The quote from the Geek Squad is $150 just to come and dx...then figure...
normaly if picture is good and audio is crackling you have a connection issue such as a bad connector cable from your devise. try replacing you cables before you call for repair.
Jan 29, 2011 | LG 42LC2D 42 in. LCD HDTV
47LG70 - PICTURE WENT OUT. STILL HAVE SOUND. HEARD A POPPING NOISE WHEN PICTURE WENT. TV IS ONLY 1 1/2 YEARS OLD. ANY IDEAS WHAT MAY OF HAPPENED.
I have had the same problem off and on with my 47LG70 for months. When the "popping" noise happens, the blue light in the corner stays on, so I know the tv is still on (sometimes I still have sound, sometimes I don't). Sometimes the screen goes black, but other times it is blue. If I turn the tv off then on again, it might stay on for seconds, minutes or hours. It's been very frustrating.
This seemed to happen right after I got my new Comcast box, which came with an HDMI 1.3 cable. I read somewhere online that this tv might not be compatible with that cable, so I unplugged it and am using component cables again. I just did this today, so I don't know if it will work, but so far the tv has been on for 30 minutes with no problems.
I'm pretty ignorant about HDMI compared to component cables. I imagine I will not get as good a picture with the component cables, but I am willing to sacrifice quality if I can just get the darn thing to work. Mine is also only 18 months old.
Hope this helps. If it doesn't, maybe someone else out there can help us both.
Sep 21, 2010 | LG 47LG70 42 in. LCD TV
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Apr 29, 2010 | LG 37LC2D Television
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Problem with the HDMI input
check with another source or cable. you likely have a bad hdmi input, this would require a new SSB module to fix.
Dec 07, 2008 | Philips 42PF9830A 42 in. LCD Television
Visio 32 with very little audio
If under warrenty then call vizio!
I believe its sound board but I could be wrong.
No easy fix, the part is 220$ service is 210 a used LIKE NEW 42-50 inch is 500$ shipped !
Sorry to say this but it happened to my 50 inch just before I heard a pop then it would not show a picture and had no sound.
Call them up if your tv is less then 1 yr old!
May 19, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VO47L 47 in. LCD TV Logo
437 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
