My dvd drive doesn't read my dvd...any dvd in my player doesn't show up on my desktop, it doesn't play, and it doesn't eject.
  • 27,725 Answers
make sure that the dvd drive is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 29, 2010
The cd wont eject from cd player in my seat ibiza 1.4 diesel 2010
Open my computer and right click DVD icon and also option show eject and press it.
Open command prompt and type command, like your DVD rom drive name "E" then go to E drive under and type eject Command.
If not solved then i share a link please visit and read it. and follow instruction.
http://www.wikihow.com/Remove-a-Stuck-CD-from-a-Car-CD-Player
Thanks,
Apple Technical Support
Jun 09, 2014 | Computers & Internet
I have an HP pavilion slimline s3600f desktop pc and the optical disk drive doesn't seem to be reading cd's or DVD's.
Check the Device Manager to make sure that the OS does not have any issues with the device. If there is an exclamation point ( ! ), then Windows has issue with it. If there is an " ! " then right-click on the device and select update driver.
If the drive shows in My Computer, right-click on the drive and select "eject" from the list. This will verify that the OS is talking to the device.
Check your BIOS settings to make sure that it appears in the BIOS and is not disabled.
Also, Microsoft recently released an update to disable Auto-Play on CD/DVD drives. If Auto-Play isn't working (due to this update), then put a music/movie cd/dvd into the drive and open Windows Media player and try to play the disc through there.
The drive may not be "broken" it just may be that auto-play has been turned off by Microsoft.
May 24, 2011 | HP Pavilion Slimline s3600f Desktop PC
The door of my Toshiba sd-6100 dvd player will not open. There's a dvd inside and it will play but it will not eject. How can I open it manually?
Try unplugging the DVD player from the outlet for 2-3 minutes to reset the unit. If this doesn't help, the player probably needs to be serviced.
I hope this helps.
(if the unit is out of warranty, you could try opening the case and removing the DVD drive. There should be a manual ejection button hidden on the front of the drive. Unfortunately, doing this to get your DVD out voids the warranty, if it is still under warranty. Each manufacturer puts this button in a different place. On computer drives, the faceplate has a hole to indicate the spot. The ejection usually takes some force with a straightened paperclip (or small allen wrench).)
May 12, 2011 | Toshiba SD6100 DVD Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Doesn t reading the cd
hey,
also mention how old are ur CDJ and does it play original cds. Did you get any error code.
thx
djajay
Jan 23, 2009 | Pioneer CDJ-1000 CD Player
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Can't Play Dvds
Just wondering if you have tried a good DVD Cleaner and see if that Helps you out sometimes the optics on the laser gets so much dust it can't read the DVD and will more than likely read CDs but not DVDs Try that see If it works. I have the same computer and two burners in it, and have had the same thing happen just a good cleaner and I was up and running,
Dec 22, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
