Question about Passport 8500 Radar Detector
False laser alerts, service required - Passport 8500 Radar Detector
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Laser warning - Multiple false alerts
Although the detector could have internal problems, it is possible that it is coming from a real source.
A route I took between home and business triggered mine along the same stretch every time I passed it and after looking a a map and comparing it with the stretch I drove, I found that the Marine airbase at Miramar California was visible (line-of-sight) between two mountains only along that stretch.
Note if the falsing happens at about the same point each time.
I just learned to ignore the laser alarm if it triggered during that 1-2 mile 'window.'
Posted on Jul 11, 2008
Laser alert constantly goes off
Laser is very sensitive to false alarms often set off when driving by an airport, or military base. Set your laser on City Mode and pay attention exactly where it goes off. Mine goes off constantly in the same place which is a air force base in Tucson, AZ. Unless you drive like crazy shut it off in the city although the cops like to use a hand held one in school zones. In 6 years of driving in Arizona I have had one real laser alert, and other than false alerts, real ones are far and few in between. Check when and where the unit alerts and use different sensitivity settings. One more thing, if your laser warning goes off you already have the ticket since the cops use them at close range unlike the radar bands. Hope this helps.
Sep 29, 2014 | 2012 Pro Sti Magnum Dash Mount Radar...
The Cobra XRS 9445 14 Band Radar Detector false alerts....
mine does the same thing...b4 i had the same model and it never did this...do u happen to have an aftermarket security system in your vehicle
Jun 10, 2010 | Electronics XRS9445 Radar Detector
Validating in jsp
JavaScript Form Validation JavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Form data that typically are checked by a JavaScript could be:
  • has the user left required fields empty?
  • has the user entered a valid e-mail address?
  • has the user entered a valid date?
  • has the user entered text in a numeric field?
Required Fields The function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
function validate_required(field,alerttxt)
with (field)
if (value==null||value=="")
alert(alerttxt);return false;
else
return true;
} The entire script, with the HTML form could look something like this:
<html>
<head>
<script type="text/javascript">
with (field)
{alert(alerttxt);return false;}
else {return true}
} function validate_form(thisform)
with (thisform)
if (validate_required(email,"Email must be filled out!")==false)
{email.focus();return false;}
</script>
</head> <body>
<form action="submitpage.htm"
onsubmit="return validate_form(this)"
method="post">
Email: <input type="text" name="email" size="30">
<input type="submit" value="Submit">
</form>
</body> </html>
E-mail Validation The function below checks if the content has the general syntax of an email.
This means that the input data must contain at least an @ sign and a dot (.). Also, the @ must not be the first character of the email address, and the last dot must at least be one character after the @ sign:
function validate_email(field,alerttxt)
with (field)
apos=value.indexOf("@");
dotpos=value.lastIndexOf(".");
if (apos<1||dotpos-apos<2)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
if (validate_email(email,"Not a valid e-mail address!")==false)
</script>
</head> <body>
onsubmit="return validate_form(this);"
method="post">
</form>
</body> </html>
P.S.: If this information was helpful, please rate this solution.
Mar 13, 2009 | Sun Java Programming Language (cdj-275)
Validation code using single loop for multiple fields in javascript
As example, use it:
JavaScript Form ValidationJavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Required FieldsThe function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
with (field)
else
return true;
}The entire script, with the HTML form could look something like this:
<html>
<head>
with (field)
else {return true}
}function validate_form(thisform)
with (thisform)
</script>
</head><body>
method="post">
</form>
</body></html>
E-mail ValidationThe function below checks if the content has the general syntax of an email.
with (field)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
</script>
</head><body>
method="post">
</form>
</body></html>
Mar 04, 2009 | Computers & Internet
Jul 11, 2008 | Passport 8500 Radar Detector
False laser alerts
Bel has a firmware fix to solve these issues. It if free if your RD still is in warranty. Of course, covering the rear laser sensor may solve the problem. That isn't a really bad idea since the rear laser sensor on all radar detectors is pretty much useless anyway.
Jun 06, 2008 | Pro RX65 Radar Detector
I have a cobra radar dector esd 737 and i sdoesnt pick up cops tell they are like not even a half a mile ahead of you and tips or ideas how to get it to work better
Detecting of radar or lidar emissions depends on mounting of detector.In My experience it is best to mount it just above windscreen wipers.You must check if your detector is visible from license plate level. This is important for laser detection. For other measuring devices it's only important to be visible.Higher mounting facing downwards will reduce false X and K/Ka signals.It will reduce detecing of true as well, so it is all up to you.You must know that laser detecting only covers your car.It d'ont matter if a cop is 300m or 1800m away.X band has a large emission, and it is easily detected.K/Ka band is a pulse emitting and has a lot narrow detecting point.It is effective at max 800m.In ether case speed can be reduced 20-30 km/h in city, and 30-50 km/h on highway.
Apr 25, 2008 | ESD 7000 Radar Detector
Beltronics pro rx65
false laser alerts when sun is low..
Nov 06, 2007 | Pro RX65 Radar Detector
Printer C760
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Aug 13, 2007 | Lexmark C760 Laser Printer
Passport 8500 Radar Detector Logo
142 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
