Our OMEGA OS 546 infrared non-contact thermometer with laser mark's sensor wire were broken, i connected the fires again but now its calibration is out and it given the wrong readings. Pls help to resolve this problem.
  • 3197 Answers
SOURCE: sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Posted on Sep 02, 2009
Testimonial: "Thank You I got it working!!!!! Thanks for the help"
richardsimpl
  • 230 Answers
SOURCE: aurora 1997 i have changed the fuel pump,, fuel filter plugs,
Hi there
sounds like you done allot to this car. did you clean your gas tank? Reason i say this there are times you get bad gas that water with it. and it sounds like you got water in your tank. need to get it out. Try this get some rubbing alcohol and poor it in your tank. It won't hurt it. It will soak up the water that's in your tank. try this and let me know how it goes.
Thank you for writing to fix ya.
Best Regards Richard
Posted on Dec 29, 2009
Testimonial: "yeah, i did that this morning, the gas tank had a bunch of **** in it, changed fuel filter, tank needed cleaned same prob still thanks though"
printertech1
  • 96 Answers
SOURCE: Hello, For labels that ask sensor
What do you mean labels that ask sensor type Mark? Describe the type of media.
Posted on Oct 13, 2010
  • 2239 Answers
SOURCE: Hi ..i want to know what kind of tachometer i need to use to chek the chainsaw RPM
Boy oh boy there are a lot of tachos here, unfortunatly non i would choose, you need a tacho that picks up the spark pulse from the spark plug, not one that requires a photo tape placed on the machine, Both Husqvarna and Stihl retail good quaility tachos, just place it near the spark plug and it gives a very accurate reading, they are called DET102 the Husqy part no. is 502711401.
Posted on Jul 31, 2012
littlejose
  • 40 Answers
SOURCE: do you have a manuel a UEI inf155 INFRARED thermometer with laser?
http://www.tequipment.net/pdf/UEi/INF155_manual.pdf
Posted on Oct 19, 2012
2006 chevy implala dashboard reading engine hot ac off. Already replace sensor
Is engine overheating ? Buy a Non-Contact Infrared Digital Thermometer LCD Digital Pyrometer Temperature GM320 11 99 Non Contact Infrared Digital Thermometer LCD Digital Pyrometer... Check temp at upper radiator hose , at 221 degrees the cooling fans should come on ! If the fans come on the sensor isn't the problem isn't the problem . The gauge it self could be bad , or the stepper motor that controls the gauge .c How to repair GM Instrument Cluster Speedometer Gauge Stepper
Feb 04, 2017 | AC Cars & Trucks
My 2001 chevrolet venture minivan is over heating. Its got a fairly new water pump replaced in jan of this year, and i replaced a busted heater core hose. Then filled radiator back up with water and...
Is the vehicle really over heating would be the first thing to address . If this vehicle was brought to the chevy dealership I work at , hooking up the factory scan tool to see what the PCM - engine computer is seeing for coolant temp . Too see if the cooling fans work , too see what temp info . the PCM is sending to the instrument cluster . I know GM had stepper motor problems in the instrument cluster . The step motor is what makes the temp , fuel , speedo , tach , gauges needles move . Just replaced a cluster in a 2005 chevy cavalier , temp. gauge goes full hot after just starting the vehicle . The cooling fans should kick on at around 223 degress , do the cooling fans come on ? Given the amount of electronics on these vehicles , it maybe best to take it to a qualified repair shop . That knows how to test these systems . Without testing I would only be guessing as to what could be wrong , Unless your prepaired to replace a bunch of parts , because your going to get a lot of different cause's from on here . Testing is the proper way to finding the problem . If you don't have a scan tool to view engine sensor data parameters , temp sensor. At harbor freight they sell a Non-Contact Infrared Thermometer With Laser Targeting. This will show what the temp is .
Non Contact Infrared Thermometer With Laser Targeting
Overheating Case Study Ford Explorer 4 0 SOHC Part1
May 01, 2017 | 2001 Chevrolet Venture
My ex470 goes up but don't works (es temp is alwais 0000)
Check the fuses and battery contacts. Fuses that old can open without any current going thru them. If the battery contacts are corroded then clean them before installing a new battery
Feb 20, 2014 | Extech EX470 True RMS Multimeter and...
Calibration for craftsman 1000 degree infrared thermometer
Apparently the reason it is not accurate is that it is a Piece of crap and Sears will not stand behind it. I recommend you do not purchase any type tool that requires precision from Sears.
Jan 05, 2013 | Craftsman 1000 Degree Infrared Thermometer...
How to calibrate Ryobi digital thermometer?
Wrong. You need black body to check accuracy of IR thermometers (unlikely that you will have one). Accuracy bellow 50F is +/-3F and other ranges is +/- 1.5% of the reading.
Read the manual: http://www.ryobitools.com/product_manual/file_url/478/RP4030_656_trilingual.pdf
Jan 04, 2013 | Ryobi Tek4 Professional 4-Volt Infrared...
My digital thermometer on my brand new echelon 660 has an erradic display of the actual temp for all 3 zones even after calibration. The temp probes are not in contact with anything to short it out. I...
Steve, these thermometers have been plagued with problems and short of a total replacement of the thermometer module, there is not quick fix. Since yours is new and and still under warranty, contact the R H Peterson Company, the manufacturer of Fire Magic Grills (800) 332-3973 and ask for Technical Service. As they are the ones who make the determination on a total replacement of the module or not. Be sure to have the grill's Model Number and Serial Number handy, when you call.
Thanks for choosing FixYa.
Aug 03, 2011 | Fire Magic FireMagic Grill
1998 Pontiac Sunfire Symptoms: -Overheating
What are you going by to say it's overheating , temp gauge ? Have you test to see what the actual temp. is > Hook - up a scan tool ,what's the PCM - engine computer seeing for engine temp. ? 223 degress the PCM should turn on the cooling fan . You could buy a Non-Contact Infrared Thermometer With Laser Targeting at harbor freight ! Radiator very hot ????? What is the right temp .
Could be a bad temp gauge . Is the coolant surging inside the cooling system ? Does it have a radiator cap ? Have you replaced it ?
May 06, 2017 | 1998 Pontiac Sunfire
Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Jan 28, 2008 | Zebra Stripe S600 Thermal Label Printer
41 people viewed this question
jasbo
jasbo
