Furnace will work for about 6 hrs only in the morning.It won't work at nights at all.Furnance will turn on for a second or two and will turn off.
  • 2,019 Answers
I can't think of a reason why mornings would be different from evenings except if the thermostat is computerized and not working right.
If you have a simple 2 wire thermostat, because you don't have air conditioning, a heat pump, zones, or anything complex, you can just short the thermostat wires together in order to force the furnace to work.
Three or four wire is more common, and you need to be more careful:
  • Red to the thermostat RH or thermostat RC terminal
    The red wire is the source hot wire from the transformer.
  • Green to the thermostat G terminal. This is the color that controls the fan or the relay that control of the blower.
  • Yellow to the thermostat Y terminal. This is for control of the air conditioning.
  • White to the thermostat W terminal. This is for control of the heating.
So then you should be able to bypass the thermostat with red to white. Then the furnace will turn on the fan as well, once hot enough.
If you have anything complex, don't risk it, and call someone.
Posted on Dec 29, 2010
My furnance keeps turning off and I could go to furnance flip switch on and it only last 5 minutes then shuts off again
You may want to check the limit switch or you could have a issue with the gas valve or transformer. I would check the low voltage transformer first, Sometimes I have found that under load the transformer will open ( quit working) and will close after power is removed and it cools down, It indicates a bad internal connection.
Jan 26, 2013 | American Standard Trane Ge Gas Furnace...
Electric furnace won't light
tony this is a gas furnance do you seee a orange glow on the right hand side of unit
Jan 22, 2013 | Heating & Cooling
Furnance fan works,but the burnrs won't ignite
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace and look in the small peep hole in the lower blower door and see if there is an led light that is flashing a certain number of blinks record the number and look for a diagnostic chart on the inside of the blower door or the upper side panel of the furnace if there is no flash code present you can try resetting the power to the furnace and see if the furnace will fire up.
Sep 19, 2011 | Heating & Cooling
I have a a Ruud furnance, model UGAC 095c. The problem is the pilot light goes out once or twice a day or late night. The thermacouple was replaced, new filter also. I also observed the pilot light and lit...
check the thermocouple is tight in to the valve , condtion of thermocouple could need changing , is pilot stong blue flame could need cleaning .
Feb 06, 2011 | Heating & Cooling
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
My heater turns on the gas starts but then it shuts down
Try to locate the red and white wires either behind your thermostat or on the furnace itself. Jump them out and see if the furnace stays on. If you do it at the furnace you will need to hold the door switch down. If it runs fine, you have found your problem (the thermostat) if it goes out again, the furnace will display a number of blinks on the circuit board. Look on the reverse side of the furnace access door and there should be an Error Code chart to get you started figuring where to look next.
Nov 10, 2008 | Goodman GMS90703BXA Heater
Carrier Furnace wouldn't light, fan was running all the time.
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
May 13, 2008 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
