Back to:
Tags:
Sharp KB3300JS Stainless Steel Electric Kitchen Range
KB3300 Stainless Steel - Display not working (by 2 users)
posted by jsusanw on Jul 07, 2008
Hi -
The display doesn' t light up at all - the surface top works but the oven/microwave doors are locked. I tried unlocking but nothing happens when the display is touched - no lights either. could it be the electronic panel or is there maybe a fuse that needs replacing?
Thanks!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by rotarylab, posted on Sep 19, 2008
i stated with the same problem.
I replaced a thermal protection fuse and the microwave, oven light and control panel apparently work.
However, the oven will not bake or broil.
The control board lights up and allows me to set the temperature, but no heat at all.
Best Solution
posted on Jul 08, 2008
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2983 votes
The control unit (circuit board) uses a relay and motor to lock the door, and the board may be damaged or scrambled
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If that doesn't fix it, it may need to have the control unit repaired. We do that for folks nationwide for only $39.95 in most cases.
We have the service manual for this model, and I've uploaded it to our site for your convenience:
www.microwavedisplay.com/kb3300js_kb3300jk_kb3300jw_sm.pdf
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on KB3300 Stainless Steel - Display not working:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
Whirlpool Gas Stove Model #SF362LXSB0 Both the broiler...
Kitchen Ranges
oven door hinge pin miele H602
Kitchen Ranges
I had a beeping sound coming from my maytag range and F 1...
Kitchen Ranges
The right front and right rear are dead, is there a common...
Kitchen Ranges
My electrician needs to know the amp requirements for Jenn...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
