Question about Carousel Toys
Need to get a wiring diagram for my carousel. no movement or music just lights? Even a scamatic manual
  • 43,501 Answers
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Posted on Jan 04, 2011
Wiring diagram 1992 Fleetwood southwind motorhome complete wiring scamatics
Go to Fleetwood's site at the link below, and select model and year to download the manual. If it does not have wiring schematic, contact Fleetwood for assistance. RV Owners Manuals
Oct 27, 2016 | Cars & Trucks
1988 bounder by fleetwood , 454 , classs c motorhome , p30 chevy / gm motor home chassis . i need a complete wire diagram / scamatics for the whole thing , eng. lighting inter. extr. gen. where can
the wiring schematics for the chassis (vehicle ) will be in a workshop manual
the electric schematics for the home section will be (should be ) available from the body builder (Manufacturer)who fitted the home section.
Feb 15, 2015 | Cars & Trucks
Can I advance my slide tray manually?
A Kodak Carousel 600 has no Forward/Reverse buttons for tray movement. The only way to advance the tray with the slide change mechanism is by LIGHTLY depressing the SELECT bar. To manually advance the tray, push and hold the SELECT bar down fully.While holding the SELECT bar, you should be able to rotate the tray by hand. Good Luck!! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
Rear light wiring diagram for 1996 harley heritage flst
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 17, 2012 | Harley Davidson Motorcycles
NEED TO KNOW WHERE TO WIRE THE PARKING BRAKE TO. I need a diagram for the wiring scamatic
Simple solution i have the same one in my truck! U take that green parking break wire on the screen and conect it to the black ground wire on the vehicle and your screen will work all the time even when moveing!!! Hope this helps!
Oct 14, 2009 | Kenwood DDX-6019 Car DVD Player
I need a scamatic diagram for a 3 speed auto trana
there is a program that i use on the internet that has all the info you need including tsb's and wiring diagrams. type eautorepair.com then scroll down and you will see diy. the program costs 12 dollars but has priceless info. you will find everything you need there, and if you have any trouble they have people that can help standing by. i have used them on several occasions and their diagrams are profesional quality.
May 09, 2009 | 1988 Toyota Corolla 4 Door
Need a wiring scamatic
All systems? or just a few? You can go to http://www.hmaservice.com/ and register your vehicle (by VIN). Afterward, you'll have access to the ETM (Electrical Troubleshooting Manual) and Shop Manuals as well as Service bulletins.
Apr 23, 2009 | 2004 Hyundai Tiburon
Mr christmas double decker carousel rotation stopped.
These things are really hit or miss. The company (Mr. Christmas) is virtually useless in the realm of tech support. Caveat Emptor and all that. Personally I have no use for this sort of thing but I must admit they ARE cute (when they work)!
I met a gentleman at the Citigroup Station Model Train exhibit (where I work as a train operator during the holidays) who had a problem similar to yours (in his case it's the music which doesn't work). I offered to attempt to fix this fellow's Mr. Christmas carousel (which he bought used, strike one!). Being a model railroader, I have vast experience repairing model trains but thought this might be a challenge. I did some online research and came to the same conclusion you did (ie Mr Christmas doesn't give a *%&^ once you've bought something, and there's NO viable tech support or schematics to be found). I was nearly about to throw in the towel and return it when I figured out how to open it. I will at least get you to the innards.
My guess is that these carousels are more or less mechanically similar (this fellow has the Disney Carousel, model 94448). The carousel consists of an outer "roof" which snaps around an inner roof (where the horsie poles insert; there are four little tabs which keep it attached to the outer roof). To get the outer roof off, however, you need to carefully remove the "crown" (which is glued on with some sort of silicone based adhesive) It is glued on with some sort of silicone based glue. BE CAREFUL removing it! Once the crown is off, you'll see a screw. Unscrewing it allows you to remove the outer roof.
If you feel mechanically adept enough, continue but TAKE NOTES as there are a LOT of screws and parts from here to the bottom base (where the motor and electronics are located). Once the roof is off, you will see the light wipers and contact pad. You will need to unsolder the two wires from the sprung wipers (be careful not to lose the springs!). You can now unscrew the hexagonal nut which holds the light wiper bracket/wipers in place. CAREFULLY remove this piece! You will now need to unscrew the contact board. pull it over the central shaft. You can now remove the inner roof. Once the inner roof is removed, you can lift up the main assembly (ie the horses, &c); CAREFULLY place this aside!
You are now at the base. There are several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. FYI the whole mess is a rubber band drive (sort of like an old cassette player or VCR). If there is no rubber band connecting the motor to the shaft, that is your problem! If the motor plain doesn't work, check the wiring fro the motor to the switch!
To reassemble, just reverse the directions. HINT: the roof will only go on top of the mechanism one way, so if it doesn't quite fit just rotate the roof until it does! Good luck!
Dec 27, 2008 | Toys
Toys Logo
141 people viewed this question
Top Carousel Toys Experts
SteveAlaska
Are you a Carousel Toy Expert? Answer questions, earn points and help others
