Question about Acer Aspire 5580 Notebook
I have Acer Aspire 5580. I am facing problem with the graphic, it is showing lines and color patches. When i am extending the monitor to external display, the external monitor is showing nice graphics. I have also replaced my screen but all in vain. Please suggest some possible solution of the problem. I have Nvidia Ge force 7300 series 256 mb dedicated graphics.
    Champion:
  • 226 Answers
If you changed the screens to a working one, then you should have a clear image on the main screen, or its damaged, or one of the monitor ribbons is not seated properly. have you updated your graphics driver?
Posted on Sep 19, 2017
3 Suggested Answers
UpGrade
  • 113 Answers
SOURCE: Install new dedicated graphics card - Aspire 5738?
No, It's not. As with most low end laptops it is not possible to upgrade the graphics card. Which is a good thing, as most high end cards make the user believe that a laptop is designed for gaming, and they never are. Gaming kills laptops.
Posted on May 22, 2010
nicarta
  • 506 Answers
SOURCE: can you upgrade the graphic card in a Acer Aspire
It will not be possible to upgrade the graphic card of a laptop. Most of these chips/card on the laptop are on board on. You can preconfigure your laptop before it is shipped from the factory. Once its in the market, it may not be possible to chage these kinds of changes.
Posted on Jun 10, 2010
No display on screen in Acer aspire 5830TG with GeForce 540
If it shows on an external monitor but not on the laptop screen, either the screen ribbon cable has come loose, the inverter/ccfl has died or the lcd screen has died.
If you boot your laptop to external monitor, then unplug the monitor - try shining a flashlight across the screen to see if you can see any dataicon1.png/screen info - if you can, then the inverter/ccfl has died. If not, either the screen has died or the cable has come loose
Feb 09, 2014 | Acer Computers & Internet
When i connect my laptop via linetek vga to av converter ,it show black & white output on my tv.
you have to go into the graphics card adapter properties program and change the screen res of the affected and you must also enable multi screens in the same program. laptop #1 external monitor #2 do not use extended to other monitor rhen you get less
Sep 30, 2013 | Acer Aspire 5733...
Acer aspire 5720 graphics problems
When you say other monitor I'm assuming you are talking about an external monitor attached to the laptop? If so then you are correct if it shows the same as the monitor that is in the laptop, you have a graphics video card problem.
Apr 07, 2012 | Acer 5720-4126 PC Notebook
Hi, My acer laptop screen gets color vertical lines and cant see anything else. sometime it works fine but after some time it gets lines again
HI There,
The easiest way to troubleshoot your problem is to connect your laptop to an external monitor. If the lines on the laptop screen don't appear on the monitor, then you know you need to replace your screen and screen inverter.
If the lines appear on the external monitor as well, then your video card on the motherboard of the laptop is failing and you'll need a new motherboard or want to consider a new laptop, depending on the repair cost.
Regards,
Marcus
Nov 10, 2010 | Acer Aspire 5580 Notebook
Monitor have one line green
its either the onbaord graphics card or the lcd screen.
using a VGA cable, plug the laptop into a external monitor
you will have to hold the FN key + F6? (key should have a lcd pic on it)
if it does not work then ur onboard gaphics card is faulty.
if you get signal via monitor then its the lcd that needs replacing
Jul 09, 2010 | Acer Aspire One PC Notebook
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 9810 Screen Problem
Hi No otto,
On the bottom row of keys, you will see one marked Fn, in a different color. Hodl that and look at your top row of keys. Should be one with a laptop screen, and a monitor. The little graphics will be the same color as the Fn key. Tap that once, wait, see if the screen comes to life. Usually that key is set to choose "Just laptop screen, just external monitor, or both", with each tap.
Good luck,
Jan 06, 2008 | Dell Inspiron 6000 Notebook
If possible 2 upgraded my acer aspire 5580 laptp video card?
no the video card in laptops is inbuilt . its fixed like graphics chipset in mother board of dektop
Dec 22, 2007 | Acer Aspire 5580 Notebook
Acer Aspire 5580 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
