Question about Linksys WRT55AG Router
I neeed to open my 6 ports so i can play xbox live!
    Novelist:
  • 125 Answers
Here I have given a link so that you can open the ports for your xbox in your router .
http://portforward.com/english/routers/port_forwarding/Linksys/WRT55AG/ICUII.htm
If you do not have the port numbers, its here for Xbox
UDP ports 88 ,53 and 3074
TCP port 3074 and 53
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Posted on Dec 29, 2010
My Xbox Kinect wont play my new game because it says it needs to be updated. Would I neeed internet to update it.
Yes, you will need the internet to update the game. Usually Xbox also will give a free one month subscription to xbox live if your game is part of xbox live as well...
Jul 13, 2011 | Computers & Internet
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
I have a belkin router and 2 xbox 360 connected to xbox live. whats the settings to have on the router which allows both of us to play multiplayer on games? at the moment one computer kicks us off live...
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Computers & Internet
I need to know how to open my nat type for xbox live
X-BOX
Jan 10, 2011 | ASUS (SL1000) Router
Hi, I have a Dir-600. I'm trying to have Open NAT on this, cause I want to play Xbox live without any trouble. I have opened ports 87-89 UDP, 3073-3075 UDP and TCP. I assigned these ports to my Xbox...
NAT STRICT
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Xbox/PS3/Wii in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Regards
TOM
Sep 20, 2010 | D-Link DIR-600 Router
Xbox live servers have been interupted
You will need to log into your router and forward ports. To solve the connection issue.
Xbox LIVE requires the following ports to be open:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
More reading here: http://support.microsoft.com/kb/908874
Mar 30, 2010 | Microsoft Xbox 360 Console
Xbox live conection
Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
X-BOX
Click Here for more info
Dec 07, 2009 | Computers & Internet
XBOX Live is "connected" but i cant play any games online because the server is always "Temporarily unavailable"
xbox live has recently added three ports for wireless internet.
if you know how to open ports (protocols) on your wireless router, then the following should be open (enabled) for your xbox 360s IP adress:
TCP
: 80
TCP and UDP:
:3074
:88
:53
May 09, 2009 | Microsoft Xbox 360 Console
Cant have private chat or play games with friends
This should solve your problem
For most devices that use NAT, port forwarding is not required to connect to Xbox Live. This is especially true if you use an Xbox Live certified device. Sometimes, you may have to configure port settings on a non Xbox Live certified router or gateway.
If there is a firewall device between the Xbox console and the network device, you may have to configure the firewall to enable communication on specific network ports. If the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," you may have to configure port settings.
The following ports must be available for Xbox Live to operate correctly:
� UDP 88
� UDP 3074
� TCP 3074
To open the ports on your router see this handy website here,
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
which gives you a step by step guide.
Before opening the ports you must give your Xbox 360 a static IP address (manual) be sure to use an IP address that no other item on your network is using and is fairly high up in your range, for example if your router's address is 192.168.0.1 then you should use something like 192.168.10 for your Xbox 360.
You can also enable DMZ (Demilitarized Zone) on your router, which will open up all the ports to your Xbox 360, however NEVER use this on a PC's IP, see your router's manual on how to do this.
Once the correct ports are open for your Xbox 360, then your NAT should say open.
Nov 26, 2008 | Microsoft Xbox 360 Console
Change NAT to open
Here you go sir, follow the instructions in the link below and your Xbox live will report an OPEN NAT and it will fix your connection problems.
http://www.portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/Xbox_Live_360.htm
Hope this helps!
Feb 09, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys WRT55AG Router Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
